Some N00bish Questions...
Some fairly easy (to you all I hope) quesitons that I just can't seem to figure out..
1) What Honda emblem would work in our front grill? I don't really know of any badges off hand that would fit in there perfect...
2) Along the same lines...The steering wheel has the big A on it and was curious how everyone was going about making that a Honda emblem.
3) This one is a little more tricky, ha. I turn the headlights on and the radio lights are VERY dim almost not on and the climate control doesn't come on at all. After a little thread searching a previous owner wired in a AFR gauge and did something to cause this issue. Just curious what you think it may be...
Here is a link to his thread of what caused the lack of light issue:
https://honda-tech.com/zerothread?id=2185328
Thanks a ton, fellas!!!
ummm.....theres only one type r honda origional emlem that should fit......both front and rear should be max 1 bill......the honda steering wheel is type r by the way its not an emblem unless u can get a sticker....for the radio dimmer, try checking ur fuses....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thetunersource »</TD></TR><TR><TD CLASS="quote">get a type r steering wheelll!! weeeeeee</TD></TR></TABLE>waste of $400, buy performance
1. the type r emblem, check ebay or other jdm retail locations online
2. u may just be able to replace the cover or but the whole wheel which yes is like $400 (a waste as well if u ask me)
3. u do know if u turn the **** in the dash, i think the one on the left, the dash lights dim or brighten
idk if that was ur question but thats all i got
Haha...okay little background on me.
I'm not new to cars so the whole "turn your interior dial up" and "check fuses" is not helping... I provided a link to show what I mean.
The fuses are fine and the dash lights are on. There is a ground or resistor not connected or fried, please help me locate it or suggest where to look.
I don't want the Type R red ones, just a regular H from any old Honda like from a junkyard...Silver H that I can snag from maybe an older model Honda.
And the wheel I just get a sticker or something, because everything else on it says Honda.
Opus7
Honda Civic (2016 - Current)
Apr 19, 2019 12:59 PM
