Analyze My Duno Run
Old Jun 27, 2008 | 05:35 PM
.brad's Avatar
25 Year Member
Default Analyze My Dyno Run
I'm building my engine this summer so I took it to a local shop and strapped it to the dyno. I only got three runs during a 'dyno day' because they were really moving us through. In the end I left with really no direction which is why I'm posting this here.
These runs were on a stock 98 spec JDM B18C with the 4-1 header and Apexi Worldsport II cat-back.
My plans this summer include installing a Hondata on a p28, a straight-pipe and possibly new camshafts and cam gears. However, I think there may be some other things I need to look at first. Really my only question is why is there such a fluctuation in the bands during my run? Is my car not getting enough fuel or enough fire? Take a look at my runs and let me know what you think if you've got a minute.
[ crap, i just noticed i spelled the subject wrong ]
Modified by .brad at 10:29 PM 6/27/2008
Old Jun 27, 2008 | 07:34 PM
non-VTEC's Avatar
Default Re: Analyze My Dyno Run (.brad)
the jagged lines could just be from the correction/smoothing factor in the dynojet software. it looks fine other than the fact it's running a little too lean at the vtec crossover up until around 6700rpm.
it could use some tuning.....just wait until you do all the mods you want then do a final proper tune.
Old Jun 27, 2008 | 08:24 PM
mtber's Avatar
1. Are you throwing any codes (check engine light) ?
2. What is your distributor timing at ?
3. What ecu are you running ?
4. Have you done a compression & leak down test ?
Mashimaro
21
Dec 21, 2005 03:26 PM
fastfour
Dec 10, 2005 05:00 AM
PreludeRacer023
Mar 10, 2004 12:56 PM
Spyderwebab
Apr 20, 2003 05:44 PM
SIINSI
27
Jan 13, 2002 09:15 PM
