Skunk2 IM and TB install help ** CRX Si
Hey guys I have picked up a Skunk2 intake manfold and throttle body for my 88 CRX Si. After reading the instructions I understand that I need a 92-95 fuel rail and throttle body. Well the instructions are writen with the installer using the EG tb and I have a Skunk2 TB and it apears that there is no place to hook up the hoses that come from my MAP system on the fire wall. Also it apears that there is a place on the bottom of the tb to install a MAP sensor.
So my questions are; do I need to install a MAP sensor on the bottom even though I see no place to plug it in. Also how do I connect all of the hoses from my existing map system on the fire wall?
Thanx guys for any help.....
on our models, the map is on the firewall and thus it needs a vacuum line since its not on the throttle body. you may need to get an obd1 or a map that actually sits on the tb. can you get any pics?
^^^ After seeing that video and knowing that the EF has its MAP system on the firewall. I guess my next question is; is the plug for the MAP on an EF the same as on the EG? I would assume yes. And if it is I guess all I have to do is remove the MAP on the firewall and install a MAP from and EG.
