Dash Fuse Prolly went out
Alright so someone just finished jacking my car the other day Broke the window n what not ripped my Head unit out of place and slit the cables. Well on the way Home i turned on my car without covering the cables >.< Stupid *** me..... Anyways i got a new head unit yesterday as soon as i Wires the 12v, the igniton, ground, and the Amp On switch.
Well my head unit did not turn on >.< Then i noticed that my light didnt turn on when i opend my car door, my power lock only works when my car is fully turned on. Could you guys tell me which fuse it might be. or what its called under the Diagram?
I tried looking it up so i was quite confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burke420 »</TD></TR><TR><TD CLASS="quote">try them all.. pull them and replace them... ull see.. and check the relay and underhood fuses!</TD></TR></TABLE>
Agreed. Dont bother using the diagram unless you know how to pinpoint an issue. Those usually aren't linked all in one.. but I could be wrong. Check all of them, start pulling them and seeing whats fried and whats not. Make sure you tape up any loose wires also, dont let them just hang out like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shintakun »</TD></TR><TR><TD CLASS="quote">Damnit, I hate having to pull every one out and puting em back in... Tediou Oh well i guess i have no other choice. The under hood fuses control indash and car stuff?</TD></TR></TABLE>
check ALL of your fuses, under the hood and under the dash.
Theres a fuse puller in the actual fuse box which makes it easy to pull them.. its really not that big of a job. if you shine a flash light on them you can kind of make out if they're blown or not.. maybe that will make it easier.. than it already is
icedlee
May 1, 2005 03:27 PM
4doorRS5spd
Audio / Security / Video
Sep 6, 2002 08:29 PM
