OBD1 conversion, cel check?
Old Jun 27, 2008 | 12:58 PM
shaggyeg6si's Avatar
Default OBD1 conversion, cel check?
Okay, so the question is, so once you do the obd1 jumper harness, how do you check your cel? OBD0 you read the light on the ecu, but on OBD1 you jump a wire. How?
Old Jun 27, 2008 | 01:10 PM
thisiskev's Avatar
Default Re: OBD1 conversion, cel check? (shaggyeg6si)
there is a usually a yellow wire on the harness that you ground out. and then when you ground it, the CEL light on the dash will blink the code number.
Old Jun 27, 2008 | 01:30 PM
Default Re: OBD1 conversion, cel check? (thisiskev)
just curiousity, an more so for everyone else, where could i find this yellow wire?
Old Jun 27, 2008 | 01:39 PM
thisiskev's Avatar
on the conversion harness there are extra wires that are not used that do not go into the engine bay. one of them is for the engine check light
http://www.nipponpower.com/~ni...e.jpg
click on that and you'll see all the extra colored wires. well one of those is for the CEL and its usually yellow. you should have got instructions with your conversion harness that tell you what each wire does and where it goes.
Old Jun 28, 2008 | 01:02 PM
Thats the thing though, I am looking into making my own conversion harness.
Old Jun 28, 2008 | 06:40 PM
dr_latino999's Avatar
If you convert it yourself, and follow everything to the T, your CEL check will be the two prong connector by your glove box.
Old Jun 28, 2008 | 08:21 PM
93excivic's Avatar
If you have the obd0 to obd1 wiring harness then its the yellow wire which is at D4 (obd1 plug), and if you convert it your self tap a wire to D4 and the other end touch ground and do the same proceeder like the obd1 car and your check engine light will blink the same as the obd1. Good luck
Old Jun 28, 2008 | 08:30 PM
gibsanez's Avatar
If you do it DIY, just use the stock 2 pin connector under your glove box just like OBD1, except it will blink on your dash like OBD1 instead of on the ECU.
I did a DIY OBD1 conversion and the actual CEL on the dash blinks just like an OBD1 car would.
Freemananana
22
Oct 20, 2013 03:01 PM
cardinalredeg
11
Aug 17, 2010 06:07 PM
91highryda
Oct 6, 2007 08:24 AM
1gEF-8
Aug 10, 2005 01:54 AM
Renegade
Jun 23, 2004 08:54 AM
