gsr 50 shot dry?
Old Jun 27, 2008 | 11:17 AM
hastingsr's Avatar
Default gsr 50 shot dry?
I might buy a zex dry nitrous kit off my friend. I have a 95 gsr, will it need any tuning to just run a dry 50 shot? other then plugs and maby uping the timing to run a higher octane?
Old Jun 27, 2008 | 01:26 PM
sjbmx's Avatar
is your car stock? if so this isnt recommend but ya the kit should come with everything you need
Old Jun 27, 2008 | 01:38 PM
darkdementshun's Avatar
Default Re: (sjbmx)
A 50 shot shouldn't be a problem as long as it is done right on a healthy engine.
Do a search in the forced induction section. There is quite a bit of nitrous info floating around...
Old Jun 28, 2008 | 06:06 PM
hastingsr's Avatar
the motor runs strong only 110k on it, got a act street disc, hd pp, prothane motor mounts, and fidanza flywheel, i would only use it about once a week AT MOST, probly not even that, from my searching and from what i can understand all i will need to run a small 50 shot would be to retard the the timing 2 degrees and to run colder plugs, now would i be able to run normal unleaded fuel when im not using the bottle and the use 93 octane when i run it?
Old Jun 28, 2008 | 07:31 PM
tsdneil's Avatar
Default Re: (hastingsr)
i was under the impression that it is recommended to run premium in vtec engines due to higher compression, right?
Old Jun 28, 2008 | 07:58 PM
loudandlow's Avatar
Default Re: (tsdneil)
The premium in WA is mostly 91 octane, which I think is where "Premium" starts. Its what I run in my GSR and it seems to do fine.
Old Jun 28, 2008 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hastingsr &raquo;</TD></TR><TR><TD CLASS="quote">the motor runs strong only 110k on it, got a act street disc, hd pp, prothane motor mounts, and fidanza flywheel, i would only use it about once a week AT MOST, probly not even that, from my searching and from what i can understand all i will need to run a small 50 shot would be to retard the the timing 2 degrees and to run colder plugs, now would i be able to run normal unleaded fuel when im not using the bottle and the use 93 octane when i run it?</TD></TR></TABLE>
Sounds like you are on the right track. Just run premium fuel all the time. It will be nice to help prevent all that unwanted detonation when you do spray, and won't hurt anything other than your pocketbook the rest of the time.
Other than that, get some nice tires and post up some time slips!
Old Jun 28, 2008 | 09:31 PM
RockyMtnTEG's Avatar
Default Re: (sjbmx)
Dry shot?? scary!!! wet is a much better way to go, granted your getting it from a friend so its available however, wet is a much safer way....good luck
Old Jun 29, 2008 | 06:29 AM
dc4_wHORE's Avatar
Soldering Iron Wizardry
Default Re: (RockyMtnTEG)
run good gas, make sure your timing is at 0 (no advance or retard) and run it, then check your plugs. It's only recommended you change plugs on anything over 75 shot. you will be fine.
Old Jul 6, 2008 | 09:07 PM
hastingsr's Avatar
thanks for the tips, yes I would rather have a wet shot but I cant complain because I am getting this whoel kit for 200 bucks off my buddy, dry is stupid easy to intstall witch is a plus too, I am just looking on a mild set up to hopefully get into the low 14s
lazyxmofo
May 12, 2008 03:02 AM
Griff
Jul 16, 2004 11:36 AM
sicklexus1
Jan 29, 2003 03:30 PM
shift6
Oct 17, 2002 04:49 PM
teg2000
Aug 19, 2002 06:34 AM
