huge partout Bseries and EF stuff
Old Jun 27, 2008 | 10:50 AM
neofreak's Avatar
Default huge partout Bseries and EF stuff
the time has come, i have my eyes on another project so i need to make room.
EF autopower roll bar painted gray, its the race model with a solid mount harness bar and diagonal bar: $350
Password:JDM rear strut tower bar with badge, very good condition: $100
Avid EF traction bar, mounts up where your factory front tow hooks are: $200
Hasport EF b series mounts cable trans: $200
Ksport coilovers, 5000mi on them: $400
Ksport Lower control arms: $75
Cable J1 trans no grinds: $400obo
B16a block, completely disassembled but i have all the parts. one of the pistons has a gouge in it from where it hit the valve, cylinder walls and rods still good: $250
B16a head, has been milled .015, has 3ang valve job, has omni Ti retainers and omni dual valve springs installed, as well as omni flat valves, but 4 are damaged. however i jumped timing and broke 2 exhaust valves causing those valve guides to crack and it bent 2 exhaust valves causing those guides to crack. combustion chamber has a small knick in it: $400
Supertech Bronze valve guides, both exhaust and intake still sealed in the package: $70
Omni Flat valves: $150
Blox intake manifold, Brand new: $150
skunk 2 carbon composite fuel rail, Brand new in box: $170
OEM honda PCT (civic type R) pistons, brand new in box w/wrist pins: $180
OEM honda piston rings: $100
Omni 2.5" adj. length test pipe, Brand new: $75
Samco Blue radiator hoses, 5000mi: $75
Buddy Club spec 3+ cams, 5000mi: $350
Buddy club Gold adj. cam gears, 5000mi: $150
OEM honda valve cover, black with silver lettering. not sure if its powdercoat or paint, but it looks damn good: $100
Vision Carbon fiber plug wire cover: $75
Buddy Club titanium silver oil filler cap: $35
VIS SIR carbon fiber hood for a USDM front end: SOLD TO MYLILCIVIC
Tri-Y header, was told its a hytech productions not a knock-off. it does have some damage on the bottom but nothing serious, just a slight dent: $400
ARP 9mm rod bolts: $70
autometer cobalt tach and shift light: $200
Boomslang obd0 to obd1 jumper harness: $100
I'll sell it for $140 with a denso 4 wire o2 sensor
B16 alternator with AEM pulley on it: $40
Buddy club headgasket, brand new in box, $80
OEM 91 front bumper, white with foam and brackets - good condition: $70
OEM 91 rear bumper, white with foam and brackets - good condition: $70
stinger battery, should be good still - $50
precision 310cc injectors: $180
MSD ignition coil: $30
Clear red MSD obd0 distributor cap: $10
CRX/EF gauge cluster, unknown condition: make offer
never thought i'd post this list. shipping not included
i've also got a single cam CRX HF exhaust manifold, sandblasted and painted high temp black. good for budget turbo projects: $40
and a BMCrace flange to bolt any t3 turbo to the HF exhaust manifold, brand new just paid $55 for it: $40
Modified by neofreak at 1:04 PM 6/30/2008
Modified by neofreak at 11:47 AM 7/2/2008
Modified by neofreak at 6:47 PM 7/5/2008
Old Jun 27, 2008 | 09:02 PM
neofreak's Avatar
Default Re: huge partout Bseries and EF stuff (neofreak)
51 views and no bumps.
i also have a 255 walbro new in the bag with install kit: $75
Old Jun 27, 2008 | 09:25 PM
crxdrosky's Avatar
bump for a good guy
Old Jun 28, 2008 | 01:03 PM
BenjyJ's Avatar
bump for a straight guy!! good stuff!
Old Jun 28, 2008 | 03:23 PM
HxCforever's Avatar
if only i didnt just pay my rent i'de buy that hf mani and adapter plate. i'll see if it's available in a week
Old Jun 29, 2008 | 09:00 AM
neofreak's Avatar
bumpin it up. buy my stuff so i can go Kseries
Old Jun 29, 2008 | 02:52 PM
Sean5826's Avatar
imed you about the trans, cash in hand!
Old Jun 29, 2008 | 02:57 PM
Ekfreddy's Avatar
Is the blox intake for the b16a will ir work on a b16a2 let me know
Old Jun 29, 2008 | 02:58 PM
daDreams's Avatar
Default Re: huge partout Bseries and EF stuff (Sean5826)
bump for schaumburg toyota! not!! bump for steve! i need axles! fast and dibs in the ksports! -marcus
Old Jun 29, 2008 | 04:13 PM
neofreak's Avatar
Default Re: (Ekfreddy)
yea the manifold will work on any B16 or B18C5
Old Jun 29, 2008 | 04:21 PM
Sean5826's Avatar
Default Re: (neofreak)
hey man still says your online, are you getting my PM's or are you just not interested?
Old Jun 30, 2008 | 07:49 AM
neofreak's Avatar
Default Re: (Sean5826)
bumpin it back up and responding to PM's
Old Jun 30, 2008 | 09:22 AM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
bump for good stuff
Old Jun 30, 2008 | 12:07 PM
jdm_cert's Avatar
pm`d
Old Jul 1, 2008 | 04:45 AM
neofreak's Avatar
morning bump
Old Jul 1, 2008 | 11:36 PM
neofreak's Avatar
bumpin
Old Jul 2, 2008 | 05:59 AM
dpaton's Avatar
Bump for a great guy with his eyes on a new toy
Old Jul 2, 2008 | 01:19 PM
yoRt's Avatar
Default Re: (dpaton)
pm'd good prices
Old Jul 3, 2008 | 08:28 AM
blueEM1's Avatar
Default Re: (yoRt)
interested in that test pipe.
Old Jul 3, 2008 | 09:46 AM
neofreak's Avatar
Default Re: (blueEM1)
lemme know
Old Jul 3, 2008 | 10:18 AM
DA9tegra's Avatar
will those ksports fit a DA
Old Jul 3, 2008 | 07:53 PM
yoRt's Avatar
how much shipd for the lca's? i got cash in hand for paypal lmk
Old Jul 3, 2008 | 08:08 PM
banginek96's Avatar
what rods are are the ARP rod bolts for again?
Old Jul 3, 2008 | 08:23 PM
neofreak's Avatar
Default Re: huge partout Bseries and EF stuff (banginek96)
they're for a b16. not sure if others are the same
Old Jul 4, 2008 | 11:13 AM
DA9tegra's Avatar
how much would it cost to ship the hf manifold and adapter plate
