Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
rsx-s brake lines
Old Jun 27, 2008 | 08:59 AM
jedi03's Avatar
Default rsx-s brake lines
hey everyone, i just did rsx-s brake conversion, was a breeze fitting everything in, only problem is my driver side ebrake line is to short...approx 1/2 inch, i was wondering if anyone knows which civic ebrake line mite fit better? i left one bolt undone w/some mechanics wire to keep it tight and not rub to much on my gas tank...just done want to rub a hole in the tank or have problems somewhere down the line...
my current ideas for ebrake lines to try are the civic si or the ex w/rear disc...dunno which ones may fit yet though...
Old Jun 27, 2008 | 09:21 AM
Boilermaker1's Avatar
Si lines are even shorter. You need to loosen the nut on the ebrake handle that controls the tension on the cables from under the console in the car. If you loosen that nut most of the way down, the line will reach.
Old Jul 6, 2008 | 09:38 PM
jedi03's Avatar
Default Re: (Boilermaker1)
tried loosening...same problem, called honda an can get new ones from civic supposedly w/discs in back for 25 on driver side...am debating if is worth it, have mechanics wire holding wire tight so will not rub on gas tank to much i hope...
Pen3
Jan 16, 2019 05:21 PM
tyoung8386
Nov 6, 2017 01:47 PM
TAP
Suspension & Brakes
Jul 13, 2010 05:32 AM
Sleepy_Red_hatch
Jul 13, 2006 09:37 AM
Pandahatch
Suspension & Brakes
May 22, 2005 11:28 AM
