Koni Yellow + ITR's Stocks
Old Jun 27, 2008 | 07:46 AM
Tiger_Si's Avatar
Default Koni Yellow + ITR's Stocks
while you guys talk about the PIC's and the koni's
i know some of you guys ride on this set up (koni yellows Lowest perk + stock ITR's)
how do you like it or dont like?
please post pics
yes, i did searched.
Thanks
Old Jun 27, 2008 | 09:12 AM
jordanitr's Avatar
Default Re: Koni Yellow + ITR's Stocks (Tiger_Si)
I'm intersted also.
Old Jun 27, 2008 | 04:10 PM
zeta's Avatar
Default Re: Koni Yellow + ITR's Stocks (jordanitr)
My ITR have yellow koni on lowest perk and stock springs, and I am very satisfied with that setup. It was the previous owner that changed from H&R spring on stock shocks - Omnipower sport coilover - current setup. He also used the car quite often on track, and was very pleased with this setup.
I have used my car on track 2 times so far, and it seems to work very good. On street I use soft setting on both front and rear. On track soft up front and hard at the rear. I am sure my car have a bit more body roll than using a typical coliover, but in my opinion it doesn't effect traction and grip any particulary
Pics in my thread:
https://honda-tech.com/zerothread?id=2220134
Also, some info in thid thread:
https://honda-tech.com/zerothread?id=485878
Old Jun 28, 2008 | 02:09 PM
Ketone's Avatar
Default Re: Koni Yellow + ITR's Stocks (zeta)
Thanks for the pictures zeta, good info!
just what I wanted to hear
Old Jun 28, 2008 | 02:52 PM
Utilitarian's Avatar
Koni FTW.
The off the shelf or revalved Koni yellows are a great match for the ITR. There's no coincidence that most of the guys in Topeka are running them and winning national titles in Solo II.
Old Jun 28, 2008 | 07:29 PM
itrdave's Avatar
Default Re: Koni Yellow + ITR's Stocks (Utilitarian)
I have KY at all corners on an otherwise stock suspension. When I first got them, had grooves machined in middle between stock and the lower groove from Koni. Car was lowered about 18 mm. Body roll was significantly reduced, but the perfect stock balance turned into horrific understeer - not cool for AX duty ! If you don't run the fronts full-soft, the car will push quite badly - this setting is basically equivalent to the stock front shocks. I run the rears full-stiff for AX, which does help the car turn better in transitions (ie slaloms), but have to run 1/4 turn under full-stiff on street for comfort.
On stock springs, I would recommend the rears strongly if you AX. I would think twice about getting fronts unless your stock units are shot...
Old Jun 29, 2008 | 08:16 PM
Tiger_Si's Avatar
thanks for the info and pic zeta.
Yup, i always believed a good pair of springs and a set of Koni's can match a lot of high end coilover systems.
Si-Yaaa!
30
Sep 27, 2009 05:58 PM
spark
Suspension & Brakes
Apr 16, 2007 05:35 PM
big pete
Honda S2000
Nov 18, 2006 11:30 AM
zijiejijeijrkjk
Jul 18, 2003 09:38 AM
outlaw racer
18
Apr 17, 2003 07:03 PM
