zc problem with swap
i had a dohc zc in the car 91 si rod went through the block so i got a new zc put it in and hooked everything up went to start it and it turned over like twice and then nothing the starter just clicks really fast but doesn't turn the engine over if any has any suggestions let me know thanks
Modified by ef_zc at 4:52 PM 6/27/2008
the clicking is coming from the starter and i have done plenty of swaps. i just don't know why it is doing that and not turning over the starter worked fine before the swap
well got a it running cleaned up all the ground and took the starter off cleaned around the starter and the block started right up runs good but theres a shitty part so i let it warm up put it in to gear ready to take it for a drive and the car won't go into gear shifter goes into 1 st put doesn't move guess i should of switched the pressure plate from the other engine this sucks
Rex_Ryder
May 4, 2005 03:57 PM
