manual conversion problem
I have recently converted my 98 si (can) ex (us) from an auto to manual it when too good to be true. Everything is in car runs great engine starts first shot revs great. For the swap I I change the intake ecu wired everything up right all lights work no engine codes. The transmission was an S40 prefect match with the D16Y8. Everything was change properly I thought. I install an aftermarket 9lbs flywheel and stage 1 clutch. Here car starts fine idles fine will smoothly shift into gear car will pull slightly and then go no where in first second and reverse a little pull and then nothing not even an 1/8 of a rotation in the tires
Is it the flywheel or is it the transmission or the clutch WHAT DID I DO WORNG
Please help
Please help
yep thats what it is...the axles arent all the way in..i snapped one of mine like that...i took off and poooooo...i was pissssssssed..got back pulled it out, at the end of the cv axle it has the little snap ring right there.. well from there up it sheared off.....just tap as obuhmyuh said
getupoffthatthan
10
Jul 27, 2007 11:11 PM
deviant1
11
Apr 4, 2004 12:52 PM
