s03 tire pressures... higher or lower?
Old Jul 18, 2002 | 12:49 PM
kkim's Avatar
Default s03 tire pressures... higher or lower?
just got a set of 195/50-15 so3s. what pressures do people who have this tire run? did you go up or down from what yuo were running previously? (assuming you were running a larger 195/55 or 205/50 tire)
this is primarily for street use.
thanks for any info.
[Modified by kkim, 9:49 PM 7/18/2002]
Old Jul 18, 2002 | 01:48 PM
seek167's Avatar
Default Re: s03 tire pressures... higher or lower? (kkim)
37.5 all the way around 195 50 15
[Modified by seek167, 5:49 PM 7/18/2002]
Old Jul 18, 2002 | 01:49 PM
Asahi's Avatar
Default Re: s03 tire pressures... higher or lower? (seek167)
that seems high. If S03 has a sidewall near as stiff as the RE730 you shoudl be able to run them around 32-33 psi on the street just fine. 37-38 psi on the auto-x course does great.
Old Jul 18, 2002 | 01:55 PM
seek167's Avatar
Default Re: s03 tire pressures... higher or lower? (Asahi)
i had thm at 34, and i was ripping some turns an it just felt real slopy
Old Jul 18, 2002 | 02:01 PM
kkim's Avatar
what size/brand/model tires did you have previous to the s03 and what pressures did you run in them?
I'm just trying to determine a good starting place from the 205/50 kumho 712's I have now. I run 38f/34r in them.
Old Jul 18, 2002 | 02:02 PM
Asahi's Avatar
High pressure ripping up turns would help. for mainly streets running high psi will wear the center of the tire pre-maturely. Just gotta change the pressure from tiem to time.
Old Jul 18, 2002 | 02:55 PM
Chris N's Avatar
I'm pretty disappointed with the 195/50's. (not the s03's, just the tire size on the car) They are so 'squirrely', darting the car left and right on all these f'ed up chicago roads. (or maybe my s03's had too much & ) Also, they seemed to make the car's handling almost too quick, compared to the 195/55 RE010's. In retrospect, I think I'd go with 205/50.... Oh well.
That said, 35 is too low up front for me. I've been at 37/35 or so all summer and they seem to wear ok and drive pretty good.
Anyone else feel the same about the 195/50's???
Old Jul 19, 2002 | 01:47 AM
DutchITR1689's Avatar
Default Re: s03 tire pressures... higher or lower? (1107)
Nope. The handling is never too quick for me. The directer the better.....
darnizzle8805
Mar 2, 2015 05:11 PM
LJRACER
10
Aug 19, 2004 09:18 AM
ZCHF
Apr 10, 2003 08:23 AM
4doorH22
11
Oct 3, 2001 04:36 PM
aLmoSt-vtec
Aug 14, 2001 05:06 PM
