will 99-00 dash directly replace a 96-98 dash??
Old Jun 26, 2008 | 05:01 PM
pjr710's Avatar
Default will 99-00 dash directly replace a 96-98 dash??
sorry about posting two topics so soon but i had two diff questions. i cam across a guy selling and interior out of a 00 .. its the darker grey so i want it. but i was wondering if the dash will fit my 97 .. theyre both ex's .. it looks like it would go right on .. but i just want to make sure
Old Jun 26, 2008 | 05:03 PM
BlueIntegraBoy's Avatar
Default Re: will 99-00 dash directly replace a 96-98 dash?? (pjr710)
The dash itself, yes. Are you looking to convert to the electronic climate control?
https://honda-tech.com/zerothread?id=605432
Old Jun 26, 2008 | 05:08 PM
pjr710's Avatar
Default Re: will 99-00 dash directly replace a 96-98 dash?? (BlueIntegraBoy)
naw definatley not .. too much work.. i would just take out my grey dash and swap it w/ the dark grey... i just want to make sure everything will match up w/ the 00 to the 97
Old Jun 26, 2008 | 06:36 PM
Hikaru's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">naw definatley not .. too much work.. i would just take out my grey dash and swap it w/ the dark grey... i just want to make sure everything will match up w/ the 00 to the 97</TD></TR></TABLE>
both 99-00 dash can go into 96-98, or the other way around, direct bolt on. The only different is the climate control and wiring harness that connects climate control to blower and cooling coil.
Since you are gonna swap the dash, you definitely have to take the whole dash out. By doing so, why not have another hour to remove the cooling coil, blower and wiring harness attached to it. Do a digital climate control swap since you have gone that far.
Bear in mind that 96-98 climate control panel can't mount properly on 99-00 dash, the other way around too.
Old Jun 26, 2008 | 09:30 PM
pucancakes's Avatar
Default Re: will 99-00 dash directly replace a 96-98 dash?? (Hikaru)
itll go in but u might as well do the climate control swap since the hardest part is taking out the dash itself.
the difference between the two is that the 96-98 dahs have tabs to secure the CC. the 99-00 doesnt.
so if u wanna keep yer current slider CC then you are gonna have to stick w a 96-98 dash
jus do the swap. i did. the labor wasnt that bad. jus taking out the dash was a PIA
Old Jun 29, 2008 | 10:40 AM
eskimo10's Avatar
The 99-00 CC swap is a lot easier than you would think to do. if you swapping the dash already once its out all you have to do is swap the motor on the bottom of the heater unit from manual to power, then switch out the whole heater blower and your done since you will already be switching out the dash and harness, etc.
bart simpson
Mar 14, 2010 07:55 PM
ThE BiG RauL
Oct 29, 2008 12:30 PM
USARICE
Feb 13, 2007 10:43 AM
babietuan323
Sep 21, 2004 11:45 PM
GroundZer0
Jan 27, 2004 08:34 PM
