Im lookin for a short shifter specifically designed for a 94-01
Im lookin for a short shifter that fits a 98 integra, not one that universally fits integra, civic, del slow, or whatever... i want one where i don't have to use washers to fill in the gaps...... any ideas or product info would be greatly appreciated
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Buddy Club I think make one specifically for a b-series linkage. Do you have something against washers or something?</TD></TR></TABLE>
they don't quite take up the right amount of space and i cant get the nut to hold it, so my nut comes loose and the shifter is all loose in turn...if that makes any sense...when im in gear, i can literally move the shifter around, there is a lot of give
I just installed a Skunk2 shifter yesterday. I used enough washers until there wasn't any space between the shifter and the linkage. It made the shifting harder since the bearing was being sandwiched. I removed one washer today and the thing shifts like butter.
So, taking up all the space isn't necessarily a good thing. Are you talking about the nut for the bolt connecting the shifter to the linkage? The stock bolt will have no problems with putting the nut back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K »</TD></TR><TR><TD CLASS="quote">to the op use more washers and make sure its got a tiny bit of play so its not too tight to shift
ok i'll try that
</TD></TR></TABLE>ok i'll try that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote"> Are you talking about the nut for the bolt connecting the shifter to the linkage? The stock bolt will have no problems with putting the nut back on.</TD></TR></TABLE>
yes i am
yes i am
Han Solo
Jan 8, 2007 01:01 PM
