my da wont start and the pump not kicking on
Old Jun 26, 2008 | 04:20 PM
berdo94da's Avatar
Default my da wont start and the pump not kicking on
well about a week about i was drivin my 90 da and i pulled up to my freinds house and i turned the car off. So i was bout to take off and the car didnt start or the pump didnt kick on so my friend towed me to my house but on the way i put it in 1st gear and poped the clutch out and the car started so i drov it home turned it off and it did the same thing again it wont start at all i have power to everything else windows head light and eveything.......so i changed the main relay and the ecu and still noting...so ya im stumped now so ya any help would be nice thanks...
Old Jun 26, 2008 | 04:25 PM
noodlez1390's Avatar
Default Re: my da wont start and the pump not kicking on (berdo94da)
sounds like what just happend to my 93 it whuldent start wen hot its probally the fuel pump main relay its like 70$
Old Jun 26, 2008 | 05:45 PM
1990tegg's Avatar
you changed the main relay... you changed the ecu... make sure your pump is working, check you have power the the pump before changing anything else
GL
Old Jun 26, 2008 | 09:04 PM
Brice.Hayden's Avatar
Default Re: (1990tegg)
the DA fuel pump is not on the top like other hondas so you can't hear it prime. if you say you can you are a terrorist
Old Jun 26, 2008 | 10:28 PM
dcRay's Avatar
Were you able to crank the motor? Is your starter out?
Old Jun 27, 2008 | 11:47 PM
berdo94da's Avatar
see thats the thing the motor wont crank at all and i checked the power to the starter and theirs power but the wird thing is that the motor its self has power i hooked up a light tester to a ground the touched the motor and the light tester came on so i think i have a bad wire somewhere and me and wires well dont get along to well
ej84dr
Jun 16, 2010 05:20 AM
integrapunk67
Feb 3, 2007 09:51 PM
rls669
12
Jun 19, 2006 05:46 PM
bogus_ek
Jun 4, 2004 10:18 AM
-DC2-
Aug 4, 2003 09:58 AM
