where does the dang ckf sensor goes to????
how do I hook this up if my harness does not have it? and also will this ONE wire make my car not run good at all? keeps giving me an no signal sensor fluation engine code. wtf is going on, my old engine didn't do this (b16)?? i'm using all the same thing, just this time it's an h22 but still using all the b16 stuff even the dizzy
96 ek hp, with b16 wiring harness (not sure what harness I have as I got the car with that swap, but do do however don't have pin c1 and c11 if that helps. and also the car now has an h22a swap. using us p13 ecu.
Modified by onefastek9 at 6:06 AM 6/27/2008
aaaaaaaaaahhhhhhhhhhhhhhhhhhhhhh helpppppppppppppppppppppppppppppppppppppppppppppp, I tryed that, but mines don't even have c1 and c11 wire pins.................................fuc$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out »</TD></TR><TR><TD CLASS="quote">well he would have known that if you posted what car/ecu/harness/motor you have *******.</TD></TR></TABLE>
wow I think that reply just helped me out now, I think my problems are sloved. thanks (count me out) fnasshole......
