1996 Power Window off track
I have seen plenty of Honda Accord windows off track.. including mine. I have taken my car to 2 shops who insisted on changing the motor and as soon as they realize that didn't fix the problem they put the old motor in gave up. What is causing this problem or where do you suggest I take it to get fixed. Body Shop, Window repair shop? Dealer...
its not that hard just takes some time. remove the door panel, u will see all the 10mm nuts holding everything toghther. loosen them all(not all the way) and roll your window up so thats its sitting properly. roll the window down and keep an eye on witch nuts move. start tightning the ones that move(not to tight) and roll the window up. most of the nuts have some play side to side when loose so its going to take some time to get the all adjusted correctly. trial and error. good luck
VTECwalka
Mar 20, 2013 09:32 AM
samson1
Jun 21, 2004 08:35 AM
