fpr question on my motor
Old Jun 26, 2008 | 11:12 AM
nick lsvtec's Avatar
Default fpr question on my motor
i was wandering if a fuel pressure regulator will be good for my motor.i have done research and havent really found what i needed.some people say yea and some say no.my setup is
81.5mm gsr block around 11:8 compression
b16 head port and polish, 3 angle valve job
skunk 2 pro 1 cams with cam gears, full ferrea valvetrain.
skunk2 pro series intake manifold with 68mm tb,hytech style tri y header, full 2.5exhaust.
190walbro fuel pump with 310 injectors.probably getting tuned on ectune.im looking to hit 200 hopefully.im still collecting parts and was wandering if i needed a fpr or would they beable to tune without.any input would be great and i have done my research just havent found a good answer.i have heard b&m is garbage and i have heard it is good.what is a good fpr.
thanks ahead of time
Old Jun 26, 2008 | 01:47 PM
b20vtech's Avatar
Default Re: fpr question on my motor (nick lsvtec)
i have use B&M and Vortech fuel Pressure reg. both are good! but u can use a stock one and be fine. My buddys got a 420whp turbo civic using a stock fuel pressure reg. running 2yrs so far nothing wrong.
Old Jun 26, 2008 | 01:50 PM
A.E Motoring's Avatar
Default Re: fpr question on my motor (b20vtech)
you can use a stock fpr, but a tuner would like the option of adjusting the fuel pressure when u have upgraded injectors instead of just adjusting injector pulse. i would go with a aeromotive regulator. or even a AEM since they have a 1:1 ratio, unless like b&M, those u have to cut your stock on and put together.
Old Jun 27, 2008 | 09:30 PM
Default Re: fpr question on my motor (A.E Motoring)
thanks for the help
Old Jun 28, 2008 | 10:58 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">i was wandering if a fuel pressure regulator will be good for my motor.i have done research and havent really found what i needed.some people say yea and some say no.</TD></TR></TABLE>
So when you did this research, what were the general reasons for using one and what were the general reasons for not, that you found?
92slowvic
16
Aug 27, 2005 08:06 PM
mengy007
Sep 2, 2004 11:38 AM
98civicEX
Feb 18, 2003 09:37 PM
WS6Dreams
Jan 6, 2003 04:57 PM
CM-R
Feb 9, 2002 02:06 AM
