4dr DA window motors the same?
Old Jun 26, 2008 | 10:03 AM
popngen's Avatar
Default 4dr DA window motors the same?
Does all the LH motors match? Ie are they identical?
Or are ALL the motors the same for LH and RH?
Old Jun 26, 2008 | 11:09 AM
denraweb's Avatar
Default Re: 4dr DA window motors the same? (popngen)
There's no such thing as a 4 door DA...
Sorry I couldn't resist...
ANyways, if I remember correctly, I believe they are identical from left to right...but front to back I think are different. Can't remember for sure or not, but they are a BITCH to change, since the damn cables coming out of them run every where in the door...
Someone care to correct/agree with me?
Old Jun 26, 2008 | 11:26 AM
popngen's Avatar
Default Re: 4dr DA window motors the same? (denraweb)
Sorry, I'm a noob at Hondas so thanks for the correction
I looked up the schematics, and it's hard to tell so I had to ask.
But I believe you may be correct. Fronts look to be the same, but the rears differ. I think I need the whole assembly and it looks like it's pretty expensive too.
Old Jun 26, 2008 | 03:54 PM
white98gs-r's Avatar
craigslist ftw. get a whole door from someone will be much cheaper
Old Jun 26, 2008 | 09:32 PM
popngen's Avatar
thanks
Old Jun 28, 2008 | 07:44 PM
denraweb's Avatar
Default Re: (popngen)
I think you would be better off at the junkyard, but craigslist would be my next suggestion.
If i may ask, whats wrong with the ones you have now? I had a problem with them and i fixed it for free...so if its just a problem like what i had, you may be in luck...
mikehawk
Nov 4, 2008 11:46 AM
cFullilove
Jan 12, 2006 09:29 PM
imonkie
Mar 12, 2003 07:28 PM
Crossett
Nov 30, 2001 05:15 AM
yaksplat
Sep 22, 2001 07:21 PM
