working on car right now please help?? code P1337 after h22 swap?
Old Jun 26, 2008 | 09:23 AM
onefastek9's Avatar
Default working on car right now please help?? code P1337 after h22 swap?
one of my buddys have just done a h22 swap into a ek and now it's running like crap when you start it right up, trows a code (P1337) engine rpm no signal, what can this be and how do I fix this. the car is on the stock ek single wiring harness with all the single dizzy stuff inside the housing of the h22 dizzy. Please help me.
Old Jun 26, 2008 | 09:29 AM
lluks_844's Avatar
Default Re: working on car right now please help?? code P1337 after h22 swap? (onefastek9)
what ecu? whar year motor? my guess would be the CKF sensor
Old Jun 26, 2008 | 09:52 AM
onefastek9's Avatar
Default Re: working on car right now please help?? code P1337 after h22 swap? (lluks_844)
obd2 engine, 97 civic dx. ckf sensor is right, but what wires do I make into the ecu pinouts? that's my main problem.
Old Jun 26, 2008 | 12:25 PM
onefastek9's Avatar
ckp rewired all the way to ecu, new ckp installed. tdc sensor rewired all the way to ecu, tdc sensor changed. still same thing, wtf is going on with this car,
what can cause this to go on?
Old Jun 26, 2008 | 12:35 PM
onefastek9's Avatar
what's funny is the car will run perfect with a hondata s300 with a base map of any b and h maps, but will run like **** with an check engine code for any other ecu. HELPPPPP
americanzero7
Jun 18, 2013 06:17 AM
d601
Jul 29, 2011 05:04 PM
chas92h22
Dec 31, 2007 05:20 PM
hondasport2000
May 1, 2006 03:51 PM
fast+forward
Oct 8, 2003 08:01 AM
