which intake manifold ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex1z7 »</TD></TR><TR><TD CLASS="quote">ITR cus I like OEM.. </TD></TR></TABLE>
This will not fit the P72 head on the B18C1.
stock manni is best for the c1. The dual stage runners really help with overall torque and hp. Most aftermarket IM are designed for turbo applications ie sk2, blox. What are your goals? if it is more of a mild build, spend your money elsewhere you will make more power. ITR cams in a c1 with a good tune will make your alot happier than an IM. Unless you are going turbo, then i would go with the sk2.
1.8T_EG
May 6, 2003 06:16 PM
