TIG and exhaust tubing
Old Jun 26, 2008 | 04:52 AM
mkehler's Avatar
Default TIG and exhaust tubing
For 16ga 304 stainless exhaust tubing, whats the favorite in terms of # of passes and filler? I've seen single fusion pass, single pass with filler, and 2 passes with filler. My custom exhaust I had made up 5 years ago was just fusion weld, and its held up great, even though looking from the inside now I see that only 50% of it was full penetration. I'm guessing 2 passes with filler is the norm?
thanks
Matt the TIG Noob
Old Jun 26, 2008 | 05:45 AM
DESTROYER's Avatar
single pass, 0.045" filler.
Old Jun 26, 2008 | 07:24 AM
danielm3's Avatar
Default Re: (DESTROYER)
Yeah, really no need to do 2 passes on 16g stuff.
Old Jun 26, 2008 | 10:52 AM
9bells's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DESTROYER &raquo;</TD></TR><TR><TD CLASS="quote">single pass, 0.045" filler.</TD></TR></TABLE>
This is exactly it. Works great. Somewhere between 30 and 40 amps.
Old Jun 26, 2008 | 10:59 AM
mkehler's Avatar
Default Re: (9bells)
Thanks guys, 3+ so I'll take it . So far I've had good luck with 50a, but I dont' know if I'd get a puddle going with less (Miller Syncrowave 200) unless I'm there for days. Or are you starting it with 50 and then dropping down?. Using 2% thoriated 1/16.
Old Jun 26, 2008 | 11:51 AM
DESTROYER's Avatar
i sit between 30-50 amps, start hot then you work your way down as the material heat soaks a little.
Arsenal
Apr 8, 2006 10:28 PM
stylin-teg
Nov 29, 2004 04:53 PM
94hondaaccordlx
Sep 16, 2004 02:05 PM
Luserkid
Apr 23, 2004 03:03 PM
turbolag98
Sep 12, 2003 05:36 PM
