low rpm shake
Old Jun 26, 2008 | 04:30 AM
Dumpy2's Avatar
Default low rpm skake
I drive a 95 accord ex. It shakes at low rpms, around 1800 - 2000. It use to only do it when it was under load (driving down the road) but now it does it a little when it is parked or in neutral as well. It isn't a really bad shake usually, but you can feel it. If you hit just the right rpm though, it will shake pretty severely.
I just did a tune up, involving new:
-plugs & wires
-distributor cap & rotor
-fuel filter
-intake
-exhaust
-valve cover gasket
Got everything put back together and the shake is still there. I have pretty much done everything my skill allows to try and remedy the problem. I am just trying to get an idea of what it might be, so I know how much I am going to have to shell out at a shop.
Thanks in advance for any wisdom you could share.
Old Jun 26, 2008 | 08:31 AM
99accordFX's Avatar
Default Re: low rpm skake (Dumpy2)
One thing U might want to check is the Injectors. With the engine running pull out, (1 at a time) each plug wire. See which one shows no change in engine idle. If you find one that doesnt change how car is idleing , then check that injector see if its pulseing. Us a pry bar or metal bar and place one side on injector and other to your ear. Sometimes you can hear if its ticking or not. Also check power to the injector. See if its getting anypower. If that doesnt work (Or if injectors are working fine) then mabye check cylinder compressions on each cylinder. See if one is considerably lower than other.
penance76
Nov 11, 2011 02:21 PM
kayjay7
May 28, 2010 04:43 PM
blackcivic11
17
Sep 18, 2009 08:15 AM
jdm341
Apr 28, 2009 09:29 AM
kyosuke714
Oct 15, 2005 07:56 AM
