headgasket thickness question (milled surfaces)
Old Jun 26, 2008 | 02:28 AM
B18CUL8R's Avatar
Default headgasket thickness question (milled surfaces)
im building with a resurfaced b16 head and a decked b18b block w/ stock rods an rs machine pr3's
would it be safe to run a .03 headgasket?
the head was only resurfaced and has stock valves
the block will be milled the minimum amount possible (i havent gotten it back yet from the machine shop so i dont know how much is going to be taken off)
any insight would be helpful
please dont link to me the zeal calculator lol
Old Jun 26, 2008 | 08:57 AM
inspyral's Avatar
Your best bet would be to clay it to be sure, but you'll probably be ok if you're running B16A cams. How big are the valve reliefs on those RS Machine pistons? You could always enlarge them a little if you needed to.
Old Jun 26, 2008 | 12:28 PM
B18CUL8R's Avatar
Default Re: (inspyral)
im not too sure about the reliefs
this would be my first engine build (i decided i wanted to learn something)
im using stock b16 cams
i threw the old headgasket away and i dont really want to ruin another just for claying but i know the procedure should be done.
basically im wondering if anyone with a milled block and head used a .03 and got away with it
thanks peeps
El_Capitan
Dec 10, 2007 06:44 PM
MOVEOVER
Jan 27, 2007 12:45 PM
1SlowB16EF
Apr 4, 2005 04:02 PM
Drag-On
Nov 9, 2003 11:11 AM
