Misc stuff for sale
b18b1 block with all internal down to oil pan. Missing timing cover, tension, and cooler pipe. $100
b18b1 head complete internals with bare manifold - $100
b-series dc headers w/ o2 - $130
99-00 si injectors w/clips - $50
99-00 si engine mount bracket - $20
99-00 si ac compressor - $20
99-00 si (2) power steering - $20 each
99-00 si p2t ecu - $50
92-95 d16z6 aem cam gear - $50
92-95 d-series power steering - $20
92-95 d-series shift linkage - $20
92-95 si almost new (4) oem spring - $50
other stuff but I'll look into it.
TW: b18a1 block with type-r piston and b16 head, b16 tranny. Complete drop in for eg. Compression test 75/215/200/210. Bad ring or piston but can come with a complete b18b1 block .
Modified by sirt_eg at 10:17 PM 7/12/2008
Modified by sirt_eg at 12:45 PM 7/13/2008
Modified by sirt_eg at 8:14 AM 7/21/2008
how many miles on the motor. is it complete stock? My range is around $1-$150 on the block. if not I'm just going to get my old block fix up. anyone know anywhere in milwaukee that can hone for a good price. bump, cause I need to get back home.
well screw it i don't need the money you can have the whole b18b motor for 200 i know that is fifty out of your way, but i can take trades fro stuff, looking for i phone, good speackers for my daily let me know
got some mtx 12 inch subs with 200watts kenwood amp, mtx equalizer with a capacitor and everything is mounted behind the sub box. Let me know if your interested in it. about $400 with everything together. unless if anyone is interested in it will let it go for $350. Items are 2 yrs old, but still works and sound awesome.
Afternoon bump.
Afternoon bump.
afternoon bump, Someone wants a ls/vtec swap.
complete everything, i mean complete. mounts, axles, half shaft, harness, p/s, headers, shift linkage, tranny, block, head, everythingn you need to drop into a eg/ej. Custom engine harness by me so no check engine light. Comes with p2t ecu also. $2500 take it away. comes with a a b18b1 block with all internals to swap over the b18a1 or just get new rings or piston for the b18a1 block. 75/215/200/210 compression test. B16a2 head and tranny mated on a b18a1 block.
chalesfoo
Mar 8, 2010 04:36 AM
