how safe if oil squiter is block on a stock gsr block?
Old Jun 25, 2008 | 04:33 PM
alaskanlue's Avatar
Default how safe if oil squiter is block on a stock gsr block?
as the topic states, how safe is it? try search but nothing on stock gsr. the bottom is all oem parts. what will it do or happen?
Old Jun 25, 2008 | 04:52 PM
Brick Top's Avatar
Default Re: how safe if oil squiter is block on a stock gsr block? (alaskanlue)
i'm not too sure what your trying to say...
Old Jun 25, 2008 | 07:14 PM
powerfulperformance's Avatar
Default Re: how safe if oil squiter is block on a stock gsr block? (Brick Top)
You need the oil squirter if you are still using the Gsr rods and pistons. Only block it if you are using Ls crank and rods....
Old Jun 25, 2008 | 10:11 PM
alaskanlue's Avatar
gsr block with gsr crank + rods - oil squiter. all oem
TheWhopper
Jan 20, 2010 06:43 AM
ray on boost
Sep 17, 2008 08:49 AM
93LSivic
Jul 31, 2003 07:58 PM
Alpha_GSR
Dec 28, 2002 09:56 AM
