91 hatch w/b16 swap want more power
I really want to go all motor and have 200 to the wheels.
I have a b16a1 with a pr3 ecu obdo vtec on my hatchback si
The only thing I have is a carb legal aem intake, it has a blox intake manifold which im going to change for a skunk2 model. Was thinking of using the skunks2 stage 1 cams goods for about 10hp I hope. Going to install an high flow exhuast. It still has the stock hatchback one. I think I can make some power with the new one. Also thinking of changing out the throttle body..
future plans:
DC 4-1 carb legal header
high flow exhaust
skunk2 intake manifold
skunk2 cam and adjustable cam gears
bigger & better throttle body.
I want to keep the car smog legal, everyone know cali is a bitch for that
Any suggestions hit me up...
future plans:
high flow exhaust
..Any suggestions hit me up...
First thing to do is get it BARRED... You will need:
P30-A00 ECU
ECU jumper harness *Depending on REF, Some don't like them.*
OBD-1 Dizzy *B16 or GSR*
OBD-1 Throttle body. * I passed with a GSR, But the nipple for the Charchol canister bent to the left instead of bending straight up. Needs MAP sensor*
CARB Legal Skunk2 Intake Manifold
OBD-1 Thermostat housing *Again depending on REF*
Electric VSS *Again depending on REF*
DATA LINK CONNECTOR *Again depending on REF*
A stock B16 on a dyno here in Cali will produce 120-135 HP to the wheels... 200 is alot to ask for and still stay CARB approved.
I have a S2 IM, DC header,and a S2 Cat-Back. I barely noticed a difference in power... But I had 2 stage 2 STI's for a year and a half, and everything I drive feels slow compaired to them...
The State REFS like when you go to them to get your car BARRED without a ticket from the police. IMO they wont nit-pick as much...
P30-A00 ECU
A bolt on b16 will never even be close to 200, like at all.
While there are a few ways to make good power and stay cali **** legal, most of the time you will just pick legal or fast.
Why are you swapping one ITR styled copy intake mani for another?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote">can u pass with a jdm p30 or are they **** for the usdm p30</TD></TR></TABLE> usdm p30
When I put on a 92-95 throttle body from a del sol or gsr I will need to mount the map sensor on the throttle body, will the stock plug work..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote">Also I was told can put in adjustable cam gears to get a little more torque..</TD></TR></TABLE> Adjusted propperly, yes.
You still are going to be way shy of 200.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper »</TD></TR><TR><TD CLASS="quote"> Adjusted propperly, yes.
You still are going to be way shy of 200.</TD></TR></TABLE>
Yeah, like 60 or 70 whp shy of 200....hehehehe
REMEMBER IM IN CALI AND NEED TO PUT ON A CARB LEGAL INTAKE MANIFOLD...
also I can nos the bitch with a 50 wet shot and be almost good for 200hp. Hehehe
or turbo it a 5-6lbs of boost
or just supercharge it...
All thoughts running thru my head...
ls95hatch
16
Jan 13, 2004 02:48 PM
xsnrgsr
10
Aug 20, 2003 01:12 PM
