Extended Wheel Stud?
Hey everyone, well im going to replace all 16 of my wheel studs out of my Del sol. And i want to know if these blox wheel studs would be ok to use?http://jdmultimate.com/blox-racing/b...1/i-93196.aspx What benefits do i get from having extended wheel studs? And what problems will it cause me if i do put extended wheel studs? And does anyone have any pictures of there honda or someone elses honda with them on? Im alittle curious on how they look. Alright thanks everyone!
The purpose to run an extended stud is to be able to run a wheel spacer without limiting the amount of threads left on the stud. Really serves no purpose unless your planning on running spacers due to a custom offset wheel or running a set of slicks. You will also need to have lug nuts designed for extended studs whether that be open or closed end.
Do you think the Skunk2 Forged extended lug nuts will fit on sportmaxx rims? Heres a link to the s2 lugnuts and here a link on the wheels. Because im not sure if the hole on the rims will be to small for the lug nuts to fit..
http://cgi.ebay.com/ebaymotors...42575&
http://www.nlmotoring.com/XXR-...7.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports »</TD></TR><TR><TD CLASS="quote">Yeah should work, most aftermarket lug nuts are designed for aftermarket wheels.</TD></TR></TABLE> Ok thanks, you absolutely correct. I found a old thread called "Show off your lugnuts" and i seen a picture of the S2 lugnuts with the rims.. So now im satisfied, thank for the help!
answered your own question. Good luck with the wheels
</TD></TR></TABLE>Thanks! And Thanks for you help as wells!
Dont be cheap, buy ARP studs. Blox **** sucks. I ran into nothing but problems installing them onto my 92 civic si front hub and fork. I also noticed the material they use to manufacture the stud is crap. Threads were inaccurate and lugs did not screw on smoothly.
I would go with ARP hardware on anything fastener related, such better quality. I absolutely hate when products are just a little bit off
Didnt even notice he mentioned blox studs
743power
182
May 19, 2017 07:30 AM
PinoyDelS0l
Jun 25, 2008 08:48 AM
