!!!! whats the difference between gsr and ls cranks ??? !!!!
Old Jun 25, 2008 | 12:35 PM
ten-94jdmteg's Avatar
Default !!!! whats the difference between gsr and ls cranks ??? !!!!
yo I had a b18c1 turbo motor built years ago and it spun a bearing, I took the crank out and it is labeled B2. I think the machine shop put an ls crank and rods in the first time now I was gonna put a gsr C3 in but I dont think the rods will work? does anyone know what the stamps mean?
thanks
Old Jun 25, 2008 | 12:54 PM
all-mtr-teg's Avatar
Default Re: !!!! whats the difference between gsr and ls cranks ??? !!!! (ten-94jdmteg)
Those numbers and letters are used in conjunction with the letters on the block to identify bearing colors.
Old Jun 25, 2008 | 01:27 PM
Default Re: !!!! whats the difference between gsr and ls cranks ??? !!!! (all-mtr-teg)
well in that case do you know how to distinguish the gsr from the ls and the bearings I bought are standard acl will that make a difference with the cranks being numbered differently?
thanks
Old Jun 25, 2008 | 01:46 PM
look at your rods, that will tell you what crank you have since rods match the crank.
joshc697
Oct 12, 2008 11:19 AM
swapped95
Aug 12, 2007 01:47 PM
swapped95
Aug 11, 2007 03:14 PM
dem0nk1d
Feb 4, 2007 01:32 PM
B18C-EJ1
Jan 19, 2002 11:45 PM
