A/C Kit Or Piece Together from Junkyard Etc.?
Old Jun 25, 2008 | 11:49 AM
honda.lioness's Avatar
Default A/C Kit Or Piece Together from Junkyard Etc.?
1991 Civic LX Sedan here. I bought it new without air conditioning. Now I want to add a/c.
http://www.ackits.com has a kit for about $1000. OEM parts sites like http://www.bkhondaparts.com sell a new OEM compressor for about $300. What else should I buy new OEM and what do you all think I could piece together from the many junkyards chock full of Civics of this generation?
Old Jun 25, 2008 | 12:16 PM
CRXsmoke's Avatar
Default Re: A/C Kit Or Piece Together from Junkyard Etc.? (honda.lioness)
Ive got everything your need for a/c pm me
Old Jun 26, 2008 | 04:38 PM
JUN.'s Avatar
Default Re: A/C Kit Or Piece Together from Junkyard Etc.? (CRXsmoke)
man, get the compressor and the condenser brand new from ebay 1 is around 100 and the other from 180-200 shipped.......
Get some a/c lines from the junkyard and buy a new dryer ($30) and expansion valve (25). I bet your car still has the evaporator. If so, go to autozone and buy the a/c cleaner in the pressurized can to clean the inside of the evaporator........
Thats around $350-$400 but the whole system is new......
Trust me, it will be worth it........... Otherwise the car will only get cold when you run or at rainy days lol.... At least get a brand new condenser....
I have a uncut harness and from a 91 CIVIC and a 96 r134a a compressor that fits the stock D series brackets and lines... I had it on my civic once.
Old Jun 26, 2008 | 05:13 PM
Default Re: A/C Kit Or Piece Together from Junkyard Etc.? (JUN.)
JUN, thanks for the input. I just checked prices on Ebay and they are about what you say.
Two compressors are sold for my 91 Civic: Matsushita and Sanden. If I go with, say, the Matsushita, then in the junkyard as I pick up hoses etc. should I look for a Matsushita compressor setup?
Old Jun 27, 2008 | 04:59 AM
JUN.'s Avatar
exacly. All a/c hoses are the same except for the ones that connect to the compressor. They are both good compressor but if you are going to swap to a B series engine, then I recommend you to buy the sanden compressor.
I got 2 matsushita hoses since I went with the sanden setup if you need them.
Old Jun 27, 2008 | 08:37 AM
Got it, re the Matsushita vs. Sanden. Thanks JUN.
Old Jun 27, 2008 | 01:25 PM
Ldo's Avatar
Ldo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote"> ... but if you are going to swap to a B series engine, then I recommend you to buy the sanden compressor.
Great info. Can you please elaborate on why the Sanden compressor is preferred in a B-engine equipped EF?
Thanks.
Old Jun 27, 2008 | 06:35 PM
JUN.'s Avatar
Default Re: A/C Kit Or Piece Together from Junkyard Etc.? (Ldo)
Well, the sanden compressor is smaller and fits all of the aftermarket brackets to mount it to the block. If you use a stock integra PR3 bracket, it bolts into 2 holes only but its a strong fit.... This is what im using and it holds pretty strong... Also there are some issues with the matsu... compresor that hits the crossmember and fitting a fan in there is a pain.... The only aftermarket bracket that you can use with the matsu compressor is the hasport one, and it runs for about $200
I am using the sanden condensor and the stock 88-89 civic 4dr fans with a B16A engine and a pr3/stock bracket....
The sanden compressor has a smaller pulley and it rotates faster than the matsu, but the matsu might have a stronger compressor inside, so thats why it has a bigger pulley....
Old Jun 26, 2009 | 09:35 PM
jcorral2's Avatar
hello
i have a 1990 CRX and need new compressor
should i stay with the MATZ or should i get a Sanden (and why)
also should i convert to 134a
and any other thoughts are appreciated, thanks
P.S
i wont be going to any junkyards
i will be going to a Honda Mechanic
Old Jun 27, 2009 | 10:39 AM
.Manny.'s Avatar
Touching My Member
Originally Posted by jcorral2
hello
P.S
No thread Jacking NOOB!!!!
Old Jun 28, 2009 | 09:55 AM
slaya's Avatar
you can clean out the inside of the evaporator core? I thought that you couldnt only the outside
Old May 9, 2010 | 12:56 PM
ITR517's Avatar
Great info thanks!!
Old May 9, 2010 | 04:52 PM
zsoccerdude17's Avatar
FOT systems use an accumulator, TXV's use a receiver-dryer. Just clearing up some improper nomenclature.
wowowee
13
Jul 11, 2005 01:50 PM
PhiLG
Aug 4, 2004 10:56 PM
jdmintegra1994
Aug 29, 2003 10:48 AM
iwantfastcars
Nov 24, 2002 09:28 PM
Pineapple Devil
Oct 23, 2002 03:53 PM
