Kaaz LSD has different speedo sense ring gear than gsr
Old Jun 25, 2008 | 12:27 AM
zimmy709's Avatar
Default Kaaz LSD has different speedo sense ring gear than gsr
Ok, so i have just cracked my transmission open to install my Kaaz LSD and done all the steps necessary to check clearances and all to put my LSD in. Got all that and my correct shim is on the way... ok no problems... BUT i happen to take a look at the already machined into the Kaaz LSD speedo ring gear and notice that it is slightly larger in diameter as well as way off on the mesh for the gear on my speedo sensor. the transmission is a JDM sir-G non lsd transmission. (jdm gsr) from 1995. My question is is there a kaaz specific speedo gear that i have to have to mesh with the lsd, or is this lsd in fact for a different honda with a different speedo sense gear?
here are the pics for comparison
The lsd is otherwise in perfect dimensions for fitment into this transmission.
i suppose it doesn't really hold me back other than i will have no speedo and i think technically no VTEC then as well as i will have to find a way to plug the speedo sense hole in the tranny until i can figure it out. It's not my daily anyways but i would like to have a speedo.
Thanks in advance for any input.
Old Jun 25, 2008 | 12:16 PM
havok hybrid's Avatar
Default Re: Kaaz LSD has different speedo sense ring gear than gsr (zimmy709)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">My question is is there a kaaz specific speedo gear that i have to have to mesh with the lsd, or is this lsd in fact for a different honda with a different speedo sense gear?</TD></TR></TABLE>
Answer is YES.. kaaz does in deed need a special speedo gear . It is smaller then stock to work with the larger speed gear on the diff.
Contact Kaaz for the correct speedo gear.
Old Jun 25, 2008 | 04:06 PM
zimmy709's Avatar
Thank You much Sir! Kaaz has been contacted
jdmkha
Transmission & Drivetrain
Apr 18, 2010 11:41 PM
Charlie Moua
Apr 18, 2010 12:49 PM
Sleeper32
Oct 21, 2003 10:53 AM
