Hard gas pedal.throttle cable?
Old Jun 24, 2008 | 08:48 PM
TOO MUCH TORQUE's Avatar
Default Hard gas pedal.throttle cable?
The initial press of the gas pedal on my car is real stiff. Its almost like the pedal is glued to something and i have to break the bond on it. Makes not riding the clutch harder because once i do brake this bond, the amount of force needed to press the gas pedal makes my rpms go above 1500 rpms.
would a new throttle cable fix the problem? ive lubed some of the pivot areas under the dash but it doesnt seem to do anything.
car is a 2001 acura integra LS
Old Jun 24, 2008 | 09:02 PM
Jimmy's Avatar
Global Moderator
I think it could be due to ''too much torque''
I kidd, i kidd..
No seriously though pop the hood.. and follow the throttle cable and check it out..
If you've lube'd under the dash try lubing the actual throttle cable under the hood.
Old Jun 24, 2008 | 09:04 PM
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I think it could be due to ''too much torque''
I kidd, i kidd..
If you've lube'd under the dash try lubing the actual throttle cable under the hood.</TD></TR></TABLE>
i lubed that area also. something i notice is that when the car is off, it doesnt do this, only when it is on,
Old Jun 25, 2008 | 01:24 PM
anyone else experience this?
thomas188
Nov 13, 2006 01:29 PM
delamission
Jan 21, 2006 03:15 PM
LX4CYL
Feb 13, 2005 03:16 PM
jaycapz
15
Jan 25, 2005 07:00 PM
Cat
Sep 30, 2002 06:48 AM
