how much vacuum on a stock gsr
Old Jun 24, 2008 | 05:53 PM
miguel329's Avatar
Default how much vacuum on a stock gsr
i have a gsr at idle it pulling 29psi of vacuum is that normal? my ls on pulled 18 also its stock with a skunk2 manifold. its in a 95 hatch thanks for any help in advance!
Modified by miguel329 at 7:00 PM 6/24/2008
Old Jun 24, 2008 | 06:07 PM
z6hatchboy's Avatar
Id say so, my z6 pulls ~25, its not psi in vacuum though, its like hecto something.
Old Jun 24, 2008 | 06:18 PM
gsrhatch2356's Avatar
Default Re: how much vacuum on a stock gsr (miguel329)
it is measured in inches of mercury (inhg). I will be honest there is no way in hell that your gsr is pulling 29inhg. I live in texas which is pretty much sea level and I get about 23inhg. of course health of a motor has a great deal on this but even 25inhg is pushing it a little bit. higher elevations will have lower vacuum cause the air is not as dense. If I were you i would get a new gauge, in fact what manufacturer of gauge are you using?
Old Jun 24, 2008 | 07:24 PM
CALC!_JUST_du_IT!'s Avatar
Default Re: how much vacuum on a stock gsr (gsrhatch2356)
What are you idling at?
Old Jun 25, 2008 | 07:06 PM
miguel329's Avatar
its idle is just a lil under 1k rpm.... ive used 3 different gauges to comfirm.. glow gauge, and 2 autometer gauges. i thought it was psi but i will check in the morning its a boost gauge with the vacuum.. i plan on putting a turbo kit on just wanted to check and, see if you guys thought that was high. thanks for the input so far.
teamlegacy
Jul 27, 2006 05:40 AM
Gsr_Hybrid_theory
Feb 7, 2005 04:38 PM
XxRoCkMaNxNEOxX
Oct 24, 2004 09:03 AM
EARLdaSQUIRREL
Aug 4, 2004 11:18 AM
BLKMamba
Jul 27, 2001 10:47 PM
