How to fix a P0302 (Cylinder #2 Misfire)
Old Jun 24, 2008 | 04:49 PM
tom48's Avatar
Default How to fix a P0302 (Cylinder #2 Misfire)
My engine light came on and I got a P0302 ( http://www.obd-codes.com/p0302 ) - Cylinder #2 Misfire.
How would I go about repairing this? There is some oil on all of the spark plugs, so would a new Valve Cover Gasket do the trick?
Thank You
Old Jun 24, 2008 | 05:33 PM
spinimbus's Avatar
Default Re: How to fix a P0302 (tom48)
You might want to get a compression test. I think that will help show whether your piston rings are shot. Possibly the spark plug tube seals? Maybe someone with more experience can help guide you.
Old Jun 24, 2008 | 08:51 PM
The-Kid's Avatar
Default Re: How to fix a P0302 (spinimbus)
Yea same thing happen to my Dad's Galant. Some oil was found in the seals. I would definitely go ahead and replace all the tube seals. And might as well replace the cover gasket....
But first check and see if there's any sign of crack or anything (arcing?) in the spark plug wires (where the wire meets the spark plug) And I would also clean inside the tube. And might as well and go ahead and change the spark plugs.
Old Jun 24, 2008 | 09:40 PM
tom48's Avatar
Default Re: How to fix a P0302 (The-Kid)
the spark plugs and wires etc. have been replaced by the dealer 1500 miles ago as part of a recall. So, I'll have someone replace the valve cover gasket etc. then...I just found it strange that all spark plugs when you unplug them had oil on them, but only #2 would misfire.
Old Jun 24, 2008 | 11:30 PM
The-Kid's Avatar
oil on the spark plug tip. The ones inside the combustion chamber? Then i'm not so sure if it's as a simple fix as changing the seals and gasket then.....
Old Jun 25, 2008 | 04:32 PM
tom48's Avatar
you know those 4 things that you can pull out of the engine that are attached to the spark wires? These are the spark plugs, right? They all have oil on the bottom when pulled out. What other things could be done?
Old May 10, 2011 | 04:42 PM
bmwizard's Avatar
Default Re: How to fix a P0302 (Cylinder #2 Misfire)
get ready tom, it's not basic things,, i'll be after my distributor tomorrow and pluginf up egr valve.
bwiissofly
Jun 5, 2013 10:24 PM
kmeng
Sep 14, 2010 08:02 AM
vltnolia
Feb 24, 2007 08:05 AM
BB6racer
Jan 18, 2006 05:20 PM
gooberwolf
Jul 21, 2004 05:09 AM
