97 DX refuses to start *SOUND CLIP INCLUDED*
Old Jun 24, 2008 | 04:23 PM
LyghtFunky1's Avatar
Default 97 DX refuses to start *SOUND CLIP INCLUDED*
So basically, the car sat for 4 months, I went out to start it & move it, the thing wouldn't start. Thus, I replaced the fuel filter, some things I gathered which I hope you can from the sound clips are:
A) Has spark
B) Has fuel
After replacing the fuel filter, same sounds & no change.
To note, if I leave the car going for a minute or so it will turn over, but it will die a few seconds after.
http://www.trapid.net/e36/civic.mp3
TIA!
Old Jun 24, 2008 | 04:32 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: 97 DX refuses to start *SOUND CLIP INCLUDED* (LyghtFunky1)
Battery. Check the F-ing battery.
Old Jun 24, 2008 | 04:33 PM
Bought a brand new battery, didn't fix the problem.
Should have mentioned that.
Old Jun 24, 2008 | 04:58 PM
turbo-2nr's Avatar
maybe bad gas
Old Jun 25, 2008 | 08:40 AM
bump
Old Jun 26, 2008 | 07:21 AM
another bump, need help
Old Jun 28, 2008 | 07:19 AM
bump again?
Old Jun 28, 2008 | 07:30 AM
pdiggitydogg's Avatar
What color is the spark? How are you testing it? Every plug?
Its clearly not the battery - if it were, the thing wouldnt be cranking. That also eliminates the starter.
If you keep trying to start it, you will flood the cylinders w/ fuel (assuming theyre working correctly) - this will make it harder to start.
If youre continuously trying to start it, you may want to pull the plugs and let it air dry for a bit...
Old Jun 28, 2008 | 12:26 PM
jeffsciv23's Avatar
any codes?
Old Jun 28, 2008 | 03:57 PM
b16dissorder's Avatar
plugs might b bad not sparkin enuf
spooonek4
Jul 13, 2009 06:05 AM
LyghtFunky1
Apr 16, 2008 07:48 PM
Timberland237
Sep 16, 2007 03:30 PM
zacatkings
27
Mar 22, 2006 05:26 AM
rainmanef
Jan 11, 2005 08:07 PM
