highest psi level for daily/street driven teg?
Old Jul 18, 2002 | 09:31 AM
LethalX's Avatar
New User
Default highest psi level for daily/street driven teg?
on this board..
or any honda for that matter
tia
[Modified by LethalX, 11:33 AM 7/18/2002]
Old Jul 18, 2002 | 10:19 AM
X2BOARD's Avatar
Default Re: highest psi level for daily/street driven teg? (LethalX)
You're asking in the wrong section of H-T... go check out the FI board.
I know a member, Saso, on occasion runs a hybrid hatch with about 26 psi on the street... but don't know if he still does.
Old Jul 18, 2002 | 03:50 PM
Al Bundy's Avatar
Default Re: highest psi level for daily/street driven teg? (X2BOARD)
If you are talking about psi level for turbo, 8 psi sounds good
Old Jul 19, 2002 | 12:08 AM
SIK IN DA HED's Avatar
New User
Default Re: highest psi level for daily/street driven teg? (thangdovu)
8-9lbs on a b18 motor is the highest i would recommend on stock internals.
Old Jul 19, 2002 | 12:52 AM
RC211V's Avatar
Default Re: highest psi level for daily/street driven teg? (dlplayboy)
tru 8-10 lbs on stock internals but also depends on your elevation and on your temperature.
Old Jul 19, 2002 | 02:14 AM
Mr. Softee's Avatar
Default Re: highest psi level for daily/street driven teg? (JDMintegGSR)
i dont think 14psi on standalone tuned well is unreasonable.
are you talking stock internals or not? I meant stock internals fyi.
Old Jul 19, 2002 | 07:03 AM
X2BOARD's Avatar
Default Re: highest psi level for daily/street driven teg? (94goldjungsr)
With a Haltech, Hondata or similar engine management, larger injectos and a couple other fuel/ignition upgrades, you should be able to run 10-12 psi on a stock bottom end (B series) easily. Someone on the board runs 10 psi daily on a D16 totally stock internals with Hondata and above mentioned parts... no problem. Tuning takes you a LONG way. I ran 10 psi daily on my B18B with stock internals....
X2
Old Jul 28, 2002 | 04:24 PM
Blahblah's Avatar
gsr turbo, possible ? will it be reliable for a daily driven car ? how much will it cost to fix up to motor to handle around 20lbs of boost ? what else will i need to watch the car for detonating. Thanks !
97RSTEG
Jul 4, 2006 06:55 AM
LoseRPunKx182
Jul 27, 2005 05:05 PM
boostedsohc91hb
14
Feb 13, 2004 09:13 PM
BoostedD15B7
Apr 7, 2003 04:32 PM
TypeR1558
Feb 7, 2002 05:30 PM
