Anyone running 185/65/14 on their slammed cars?
Old Jun 24, 2008 | 01:23 PM
hybrid90's Avatar
Default Anyone running 185/65/14 on their slammed cars?
Anyone running 185/65/14 on their slammed cars? If so, does it rub? Just curious cuz I have a chance to buy that size for cheap...
Old Jun 24, 2008 | 01:59 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Anyone running 185/65/14 on their slammed cars? (hybrid90)
185/65-14 was the stock size on a lot of Hondas like '97-00 Civics, and it shouldn't rub on those cars, even if they're lowered reasonable amounts (say 1.5-2.0"). They can also use 195/60-14 without rubbing. However, on del sols, CRXs, and pre-'96 Civics, they might rub, and you should use 185/60-14.
What kind of car is this for (year, model, version)?
Old Jun 24, 2008 | 02:45 PM
r.wright's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid90 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone running 185/65/14 on their slammed cars? If so, does it rub? Just curious cuz I have a chance to buy that size for cheap...</TD></TR></TABLE>
depends on the offset of the wheel but if you got oem steel rims or oem alloy wheels then go ahead and slam it to your heart's desire..it wont rub
Old Jun 24, 2008 | 03:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Anyone running 185/65/14 on their slammed cars? (Opossum Jenkins)
Also, there isn't a single decent 185/65-14 tire, IMNSHO. Whereas you can get some good tires in 185/60-14 and 195/60-14 (such as Yokohama ES100 summer tires in both sizes, and, for those who need all-seasons to deal with snow as well as heat, the Bridgestone Potenza RE960AS).
Old Jun 24, 2008 | 03:27 PM
hybrid90's Avatar
Default Re: Anyone running 185/65/14 on their slammed cars? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">185/65-14 was the stock size on a lot of Hondas like '97-00 Civics, and it shouldn't rub on those cars, even if they're lowered reasonable amounts (say 1.5-2.0"). They can also use 195/60-14 without rubbing. However, on del sols, CRXs, and pre-'96 Civics, they might rub, and you should use 185/60-14.
Thanks for all the replies! Reason I'm asking is because I found some BMW bottlecaps with 185/65/14 mounted on them already. I believe the bottlecaps have an offset of +35. I was planning to mount them on my DA with about a 2.5"+ drop so that's why I was wondering if it will rub before I buy the bottlecaps.
I don't want to spend anymore money buying different sized tires.. I was just looking for cheap wheels with tires already mounted..
Old Jun 24, 2008 | 03:30 PM
r.wright's Avatar
that offset is like 14x6 +30...
i would say it will work since the DA has a lot of room under there...
Old Jun 24, 2008 | 03:53 PM
hybrid90's Avatar
Coolio! Thanks!
Old Jun 24, 2008 | 07:34 PM
nsxtasy's Avatar
H-T Order of Merit
Get the wheels/tires if the price is worth it if they didn't have tires. That way, it's like getting free tires; if the tires don't work, you're not really out anything.
Old Aug 27, 2008 | 11:23 AM
gabebauman's Avatar
They will rub on the metal rib in the top of your fender. Beat that thing down with a hammer.
Old Aug 27, 2008 | 05:10 PM
batallic's Avatar
i got a 93 ej1 i rub with oem steelies sometimes
littleblue
Jun 24, 2006 04:22 PM
94rs-turbo
Jan 18, 2006 08:23 AM
sumyungguy
Dec 14, 2005 01:54 PM
Libertariat
Sep 28, 2005 12:32 PM
MR R3P05T
Jun 30, 2003 11:38 PM
