Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Best Ground for amp for a 04 honda civic ex coupe?
Old Jun 24, 2008 | 11:37 AM
ZooYorkGang's Avatar
Default Best Ground for amp for a 04 honda civic ex coupe?
hi, im having a hard time finding a good ground for the amp. the back seat dont work dat good and the clip for the trunk isnt a good place either do any1 no wheres a better ground? thanks.
Old Jun 24, 2008 | 12:13 PM
daddy's Avatar
Default Re: Best Ground for amp for a 04 honda civic ex coupe? (ZooYorkGang)
anywhere that touches bare metal. mine is just grounded to the spare tire area.
Old Jun 24, 2008 | 02:01 PM
kenbo21's Avatar
Default Re: Best Ground for amp for a 04 honda civic ex coupe? (daddy)
I have a battery in the trunk for my system. And the ground is connected to the trunk latch. I took that plastic piece off and ran the 4ga wire to it than to my battery. There is two holes that you can run the wire threw to make it look really nice..but that is a great spot to take a ground it is already stripped and shouldn't come loose on you..at least mine hasn't and its been about 2 years now
Old Jun 24, 2008 | 04:18 PM
It Wasn't Me's Avatar
I used one of the rear suspension bolts located in the trunk. I ran 7" of 4g wire from the bolt to a distribution block, then 4" of 8g from the d.block to the amp. Your wires should be as short as possible, especially your ground.
As daddy mentioned, it has to be bare metal. (for a good ground)
wegotmorrison
Jun 16, 2010 10:47 PM
notguilty411
Audio / Security / Video
10
Oct 18, 2005 09:58 AM
juniordc2
22
Jul 18, 2004 09:58 AM
h22accordr
Jun 29, 2004 11:27 AM
D_TY3
Jun 15, 2004 01:20 PM
