ground point in the car
Old Jun 15, 2004 | 04:47 AM
D_TY3's Avatar
Default ground point in the car
Hey guys,
I am getting horrible feedback from my amp, becasue the ground point i have it on is not that great. Is there a specific area in the cabin for integra's that is a better ground point?
Thanks
Old Jun 15, 2004 | 05:44 AM
nOOber's Avatar
Default Re: ground point in the car (D_TY3)
your best bet is using your DMM set to "impedance" to find the best spot.
connect the negative lead to the negative post on your battery, and poke around with the positive lead for your ground spot. anywhere that measures less than 1 Ohm is good.
Old Jun 15, 2004 | 05:48 AM
D_TY3's Avatar
Default Re: ground point in the car (nOOber)
thanks, is there any advatage or disadvatage of just running a wire for the negative post into the cabin for a ground?
Old Jun 15, 2004 | 06:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_TY3 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, is there any advatage or disadvatage of just running a wire for the negative post into the cabin for a ground?</TD></TR></TABLE> Do not ground amp at batt., best ground for amp is to use a seat or seatbelt bolt,or any nut or bolt that go's into mainframe of car [as close to amp as posable]Don't forget to upgrade ground at batt. [add same gage ground from batt. neg. to mainframe as the power wire your running to amp] also solder all term. Hope this helps 94
Old Jun 15, 2004 | 08:07 AM
D_TY3's Avatar
Default Re: ground point in the car (fcm)
thanks
i have my amp ground to a seat bolt right now but still making all types of noise
between the info you and noober gave to me i should be ok
thanks again
-d
Old Jun 15, 2004 | 01:20 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Do not ground amp at batt., best ground for amp is to use a seat or seatbelt bolt,or any nut or bolt that go's into mainframe of car [as close to amp as posable]Don't forget to upgrade ground at batt. [add same gage ground from batt. neg. to mainframe as the power wire your running to amp] also solder all term. Hope this helps 94</TD></TR></TABLE>
make sure you sand the paint off the grounding point so you ahve good contact. another thing to check is your HU ground. do you ahve your signal wires running down the same side of the car as your power wire?
wegotmorrison
Jun 16, 2010 10:47 PM
MilanoRedDashR
Audio / Security / Video
15
Jul 3, 2009 05:44 AM
ZooYorkGang
Honda Civic (2001 - 2005)
Jun 24, 2008 04:18 PM
GoLowDrew
Jul 17, 2006 11:05 PM
ILOVEGIRLS
Feb 13, 2005 07:18 PM
