JDM ITR Brake Booster/MC Question...
I have currently installed a jdm 5 lug setup with the jdm MC/BB
I beleive the MC has ABS because the one fitting is 10MM and the other is a 12mm fitting. Im having a bitch of time finding a fitting for the 12mm 3/16s line around here.
Can i swap out the MC for another 4 disc setup? SIR? DA?
Any help would be appreciated
Thanks!
Thanks!
the parts store will sell you an m12 brake line, just buy the shortest one you can and cut the fittings off
Autozone
If you cant get it there, hit up a junk yard and pull the fittings off the main abs block from any abs honda
Autozone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport »</TD></TR><TR><TD CLASS="quote">any abs honda will have the 12mm fittings</TD></TR></TABLE>
slvrcvc93
Sep 1, 2008 04:56 AM
