Abs Master Cylinder on Non Abs car
I know it can be done all I have to do is re flare the line but does anyone know the size of the rear brake line of the abs Honda Civic 92-95 I'm going to use the 15/16 master cylinder the front line is the same as all other Civics but the rear isn't. Before I buy the line so I can get the fitting ??? Does anyone know by any chance ???????
Seagull Management
Re: Abs Master Cylinder on Non Abs car (slvrcvc93)
You need the booster that goes with that MC as well, just thought i'd add that in case you didn't know, '91 EX MC would be a better way to go IMO, just bolts up like the stock MC.
i'm having that same problem now, and nobody seems to have the right adapter fittings for me. I believe it's a m12 x 1 to a m10 x 1 you need. I may just have to buy a 1/2" line and reflare it too.
Re: Abs Master Cylinder on Non Abs car (94EG8)
Thanks 94 Eg My boy gave me the entire setup. Thank god! ABS brake boosters are not that easy to find I Have a Re Flare kit so I guess I will just buy the line cut the end off and cut my end off and Re Flare the line. I'm just worried about the size difference and a leak but if flared properly than I know it shouldn't be a problem.
Sorrole If your having a hard time finding it check summit racing they have every adapter size you can think of.
Re: (sorrule)
Im calling my local shop now i know it the same size as the second half of the clutch line on the civics so I actually have the fitting but ill get the size for you and take some pictures and turn it into a how 2 thread.
Re: (slvrcvc93)
I actually found an easier way to do it talked to brake expert and he told me that the 91 civic ex has the dual 10mm fittings. So im just going to bring mine back and tell the parts place they gave me the wrong one lol.
Re: (94EG8)
Lol dam eg I didn't even notice that I have my blown motor problem that's probably why i didn't even read it through the right way. Sorry .......
DC2MK
06-16-2008 06:53 AM
