Motor Mount Is Hard To Screw Down
I'm having a problem bolting down the back motor mount because there is no type of clearance between the firewall and back motor mount screw(keep in mind there are only two screws to tighten with innovative mounts back mount and i only have one right now but don't drive my car anymore[extreme vibration) HELP ME OUT?
Maybe get a skinny friend to stick his hand up there, you have to do everything by feel.I changed the rear mount while I did my swap, it tough....Have some patience
you have innovative mounts? that rear mount is easier to install then the Hasport because it has a cut out for the back bolt and you can thread it in then slide the mount on. you are going to need a ratcheting wrench to tighten the back bolt.
Aw hit it wit ya purse. Sorry the Title just made it sound like you were to weak to screw it down.. lol On to the serious side. As stated before you gota do it by feel kinda but make sure its torqued to spec otherwise you might have some problems.
yeah ok but should i get a craftsman self-ratcheting open key with a swivel work because i'm doing all the work myself in the middle of the street wanna do it quick and painless(without getting a ticket)
MY CAR AND MY GARAGE
Modified by endo617 at 12:40 PM 6/24/2008
THanx everything i appreciate the feedback will post new pic of my car w/ 17" rota circuit 8's i got for $350(craigslist.com)
timisyourfriend
Aug 1, 2005 05:41 AM
94gsrhatch
Nov 20, 2004 05:35 PM
