VSS issue
Old Jun 24, 2008 | 06:30 AM
fortymcpants's Avatar
Default VSS issue
I have a USDM ITR gauge cluster in my 92 hatch, the speedo has always been off. It seems to be sort of an increasing amount as my speed raises, leading me to believe its some sort of a signal issue. I also wondered if maybe it is because I am using a D series trans with a D series VSS instead of the B series that would normally be associtaed with the ITR cluster.
I am in the process of an H2B swap which would give me the B series VSS so if this is going to work then no worries, but if not is there any way to adjust or fix this problem? Thanks in advance
Old Jun 24, 2008 | 11:18 AM
Default Re: VSS issue (fortymcpants)
I'm so lonley, so lonley
Old Jun 24, 2008 | 07:28 PM
This should be a good one for BlueIntegraBoy, I used all his info to install it.
Old Jun 24, 2008 | 09:15 PM
Jimmy's Avatar
Global Moderator
Undo the VSS harness plug, check to make sure all the prongs are intact
Old Jun 25, 2008 | 07:03 AM
K, I'll clean it up, I rewired it myself because the original connector was smashed, but I depinned it and put on a new connector.
TheoneTheycallVille
Mar 1, 2009 11:29 AM
turbociv910
Jan 26, 2009 09:17 PM
crexer
Jan 29, 2005 08:28 PM
