*need timing opinions*
Old Jun 23, 2008 | 08:18 PM
steveo135's Avatar
Default *need timing opinions*
So like the title says I need some input on setting my timing...
I just finished my rebuild and the engine (B18C1) will be going in the car on wednesday... The head and block were milled .005 and I want to know how this will affect my timing?
here she is...
Old Jun 23, 2008 | 08:20 PM
all-mtr-teg's Avatar
Default Re: *need timing opinions* (steveo135)
Set it to 16. The amount you milled is negligible.
Old Jun 23, 2008 | 08:36 PM
steveo135's Avatar
Default Re: *need timing opinions* (all-mtr-teg)
good to hear
so on the first start I should let it idle untill the radiator fan kicks on then check the timing and adjust?
Old Jun 23, 2008 | 09:04 PM
Yup, then change your oil.
Old Jun 24, 2008 | 08:09 PM
steveo135's Avatar
Well I've noticed in most engine break in procedures they say to idle the car around 2.5-3k rpms for 20 min or so...
So should I let the engine break in first then set the timing or..
Let the car idle itself after I first start it up until its up to op temp, set the timing, then break in the engine...
Thanks for any input I wanna make sure I do it right
jeckel7234
Honda CR-V & Element
Mar 6, 2016 07:02 AM
josephshark
Jan 2, 2006 11:52 AM
kornerk12
Dec 18, 2005 03:16 PM
b20z2
Aug 8, 2005 11:57 AM
them8te
May 5, 2003 08:08 AM
