B16 9,500+RPMs Help
Old Jun 23, 2008 | 05:20 PM
attack666's Avatar
Default B16 9,500+RPMs Help
hey guys, this is my first time posting on H-T been browsing for ever to get what i need from the search engine so i finally decided to post a thread.
anyways im builidng a drag EK, and want to do (head work) on my B16 head which is currently stock.
I need help finding the right valves to that holds up 9500+ rpms.
feel free to throw in thoughts/ head setup
i need to know which parts work best.
Hash.
Old Jun 23, 2008 | 09:04 PM
vtecb18c's Avatar
Default Re: B16 9,500+RPMs Help (attack666)
not to be an *** but oh no not another one....use the search button...this has been covered like a hundred time..also use the drag forum...on a lighter note, welcome to honda tech
Old Jun 24, 2008 | 06:11 AM
gibsanez's Avatar
Default Re: B16 9,500+RPMs Help (vtecb18c)
What are you running for a bottom end?
Old Jun 24, 2008 | 05:20 PM
anothersickhatch's Avatar
Default Re: B16 9,500+RPMs Help (gibsanez)
the valves arent going to be the issue when revving to 9500 rpms. what you need are stiffer valve springs and retainers. i have always used oem honda valves with my applications and simply bought aftermarket springs and retainers.
to rev to 9500, you will most certainly need cams that makes power that high or it is useless. to have cams that do this, you need the compression to support them, not to mention, the proper tuning, intake manifold/ throttle body, and a good exhaust manifold.
why do you want to rev to 9500 anyway? good power means good power, regardless of if it revs that high or not. there arent a lot of all motor engines that make power that high, trust me.
Modified by anothersickhatch at 6:07 PM 7/2/2008
Old Jul 2, 2008 | 11:36 AM
attack666's Avatar
Default Re: B16 9,500+RPMs Help (anothersickhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothersickhatch &raquo;</TD></TR><TR><TD CLASS="quote">the valves are going to be the issue when revving to 9500 rpms. what you need are stiffer valve springs and retainers. i have always used oem honda valves with my applications and simply bought aftermarket springs and retainers.
why do you want to rev to 9500 anyway? good power means good power, regardless of if it revs that high or not. there arent a lot of all motor engines that make power that high, trust me.</TD></TR></TABLE>
im sorry i forgot to mention that im going F.I
I got a Type R cam sitting in the garage, ive read and heard their as good or even better than after market cams what do you think?
im running a 9.7 compression, intake mani/TB and headers are all good aftermarket.
as im new in the market, i leaning towards Skunk 2 products
i would love some recommends.
Old Jul 2, 2008 | 05:07 PM
well, if you are going to boost the motor, i wouldnt even use aftermarket cams.
oem cams are good for turbo, regardless of if they are type-r cams or not. only in my opinion. just get some stronger springs and retainers and you will be fine. save the money for something else.
Old Jul 2, 2008 | 05:59 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attack666 &raquo;</TD></TR><TR><TD CLASS="quote">im sorry i forgot to mention that im going F.I</TD></TR></TABLE>
There aren't a lot of forced induction motors that make power that high either. Not to mention the additional stress of an FI setup at that engine speed.
jceltalentoso
Jan 18, 2012 10:23 AM
Akavietboy201
Apr 14, 2009 08:47 AM
Akavietboy201
Apr 14, 2009 08:45 AM
stewie8apie
Feb 21, 2005 07:34 PM
