92-95 civic a/c bracket??
ok so im trying to keep my a/c with my b18b swap and i searched everywhere and asked around which brack i would need. I was told the del sol bracket is what i need so i got the bracket part number 38930-P54-000.
Now the problem is, it bolts up to the block no problem but my d-series compressor bolts dont line up with the bracket.... i was also told the del sol bracket part number 38941-P30-000 is the one i need but i dont want to go out and buy anouther bracket with out checking this out with you guys first
let me know what you guys think.
the car is a 95 civic ex/si coupe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by feeldabazzgsr »</TD></TR><TR><TD CLASS="quote">I am gonna do this also to my 92 EG with b18c1..and i was told to use 99 Honda CR-V bracket cause the Del sol one is more expensive</TD></TR></TABLE>
Hense ~~~> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CaMw0nDeR »</TD></TR><TR><TD CLASS="quote">B20 a/c bracket.. </TD></TR></TABLE>
ok so the b20 will line up with the d-series compressor? does the mean a crv used the d-series compressor? because the del sol one sure didnt line up (38930-P54-000)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derekhh »</TD></TR><TR><TD CLASS="quote">ok so the b20 will line up with the d-series compressor? does the mean a crv used the d-series compressor? because the del sol one sure didnt line up (38930-P54-000)...</TD></TR></TABLE>
Yes sir... CRV's use the same exact R134 compressor as the D series, thats why the brackets work my friend...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec2late »</TD></TR><TR><TD CLASS="quote">p30 will work also. Del sol with a dohc vtec motor uses a d series compressor </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by feeldabazzgsr »</TD></TR><TR><TD CLASS="quote"> i was told to use 99 Honda CR-V bracket cause the Del sol one is more expensive</TD></TR></TABLE>
stehigs321
Jul 10, 2003 01:24 PM
