VSS question
Old Jun 23, 2008 | 12:51 PM
FOMULA91's Avatar
Default VSS question
Found the D Series EF Civic and CRX Hydraulic Transmission Swap but cant find the B-series.
http://www.hondatuningmagazine....html
I was swapping a B16 motor into my 89 CRX HF and run it OBDI, so I can go BAR it legal. My point is....
-How does the VSS work for a B-series cable transmission if I go OBDI? Do I need to change it to Electronic VSS?
-I know Hasport provide cable to hydro conversion kit but how would the cluster work?
I appreciate for your help.
Modified by FOMULA91 at 3:26 PM 6/23/2008
Modified by FOMULA91 at 12:21 AM 6/24/2008
Old Jun 23, 2008 | 03:17 PM
crxfreak1117's Avatar
Default Re: VSS question (FOMULA91)
if your askin how the cable tranny's vss work they are cable opperated a cable goes to the vss to the back of the cluster
Old Jun 23, 2008 | 03:38 PM
IndySporty's Avatar
Default Re: VSS question (crxfreak1117)
You can interchange the Cable style VSS from any B-Series transmission and the Electronic VSS style. I have a cable tranny in my EF with a 2000 B16 electronic VSS to run my 2000 Si cluster.
Old Jun 23, 2008 | 09:13 PM
FOMULA91's Avatar
Default Re: VSS question (IndySporty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">You can interchange the Cable style VSS from any B-Series transmission and the Electronic VSS style. I have a cable tranny in my EF with a 2000 B16 electronic VSS to run my 2000 Si cluster.</TD></TR></TABLE>
So U basically need to swap out the cluster to make the electronic VSS work correct?
Old Jun 23, 2008 | 09:20 PM
depends on what cluster ur using if it came out of a car with a electronic vss then yes you have to change to a electronic vss sensor
Old Jun 23, 2008 | 11:24 PM
FOMULA91's Avatar
Sorry to make my topic confusing. I rephrase my main point.
Old Jun 23, 2008 | 11:45 PM
D16SiHatch's Avatar
if you go obd1 you do not have to use an electronic vss. if you have the stock cluster and intend on sticking with it then use a cable style vss in your trans. If you plan on changing the cluser out to something different that requires an electronic speedo signal, then you'll want to get an electronic vss.
Old Jun 24, 2008 | 12:03 AM
FOMULA91's Avatar
Default Re: VSS question (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">if you go obd1 you do not have to use an electronic vss. if you have the stock cluster and intend on sticking with it then use a cable style vss in your trans. If you plan on changing the cluser out to something different that requires an electronic speedo signal, then you'll want to get an electronic vss. </TD></TR></TABLE>
Thanks!!! I was just tripping cuz some people told me to change cluster, get the cable to hydro conversion kit and ect....
Thanks for the help
PayMecracka
Apr 10, 2011 07:59 AM
FOMULA91
Mar 22, 2010 05:38 PM
crawfo661
12
Oct 22, 2009 04:04 PM
rewerbcrx
Jul 19, 2007 04:28 PM
coot_er
13
May 25, 2004 07:02 PM
