whats this noise
Old Jul 18, 2002 | 06:15 AM
Mires's Avatar
Default whats this noise
I'm starting to get this knocking noise in the engine bay. It only does it idle that i can hear and then when i push in the clutch it goes away. does anybody have an idea what it is. any info would be appreciated.
Old Jul 18, 2002 | 06:17 AM
Nate B's Avatar
Default Re: whats this noise (ITR-862)
have you looked in the engine bay to try and determine the general location that the knock is coming from???? That might make it a little easier for us to try and help you.
Old Jul 18, 2002 | 07:34 AM
Mires's Avatar
Default Re: whats this noise (KILLERB18)
well when i check it out it doesnt sound like the engine. it sounds like its coming from the transmission. i had a few people tell me its the clutch but they werent sure what part. i think the clutch is stock but im not sure. is the stock clutch stiff?
mine was pretty stiff when i got it. i hope this info helps you a little better. and thanks for your help.
Old Jul 18, 2002 | 07:37 AM
reefer_bob's Avatar
What year is the car? How many miles?
Old Jul 18, 2002 | 07:45 AM
Mires's Avatar
Default Re: whats this noise (reefer_bob)
its a 2001 and it has 50,000 miles.
Nate B's Avatar
if you've felt any ACT clutch than the stock clutch feels soft, but compared to other stock Honda clutches its pretty stiff. I'm not sure why you'd hear knocking from the clutch, especially if your not moving anywhere. I honestly don't know. One thing I was going to suggest is take a look at all of your pullies/belts make sure they aren't rubbing against anything. If it is something in your tranny I would think this would only be heard when your actually moving. It also could be something inside your block such as pistons or valves, but I don't know why this would stop when you press the clutch in. All I can suggest is take it to a mechanic...good luck.
Old Jul 18, 2002 | 08:11 AM
uNF$@#!'s Avatar
holy ****.... let me know next year when you have 100k
Old Jul 18, 2002 | 08:23 AM
Nate B's Avatar
Default Re: whats this noise (Soup ****)
damn!!!! I thought I was bad with having 25K on my 2001
Old Jul 18, 2002 | 08:26 AM
oryanh's Avatar
I have it too... very quiet though.
I have a 2001 ITR with 17,000 miles.
It's always been there. I would recommend you replace your tranny fluid with Honda MTF.
Old Jul 18, 2002 | 08:43 AM
NWPNOMORE's Avatar
Banned
i'm guessing you are low on tranny fluid. That's the same thing that mine did when I was really low on tranny fluid.
suken19
Apr 18, 2007 03:01 PM
JamesV
Dec 1, 2005 06:35 AM
qcktegls
Nov 28, 2004 01:49 PM
crdcz03
Sep 24, 2004 08:49 PM
SublimeStyles
May 18, 2003 04:14 PM
