What break fluid do you guys recommend or use.
Old Jul 18, 2002 | 06:06 AM
AutoXsi2000's Avatar
Default What break fluid do you guys recommend or use.
This is for a 00 Si for track and street use. Got Hawk pads and Power slot rotors.
[Modified by mano77, 10:09 AM 7/18/2002]
Old Jul 18, 2002 | 06:29 AM
96_GSR's Avatar
Default Re: What break fluid do you guys recommend or use. (mano77)
I'm about to try Super Blue..I've heard it's the best..
Old Jul 18, 2002 | 06:34 AM
Default Re: What break fluid do you guys recommend or use. (96_GSR)
Where can i get that?
Old Jul 18, 2002 | 06:40 AM
I've also heard Motul works good also. Anyone want to interject?
Old Jul 18, 2002 | 06:43 AM
BROOD's Avatar
I use Valveoline Synthetic Brake fluid......found at any WalMart or auto parts store. Low cost and abundant. I have not needed anything more exotic yet.
Old Jul 18, 2002 | 07:42 AM
IlikeTODA's Avatar
Default Re: What break fluid do you guys recommend or use. (SLPR)
Is the stock Honda fluid not any good? Thanks, J
Old Jul 18, 2002 | 08:11 AM
reefer_bob's Avatar
Default Re: What break fluid do you guys recommend or use. (IlikeTODA)
Stock honda fluid is ok for normal street driving. But there are other more exotic fluids out there which have a higher boiling points. This is a good thing!
Old Jul 18, 2002 | 08:23 AM
Spade's Avatar
Default Re: What break fluid do you guys recommend or use. (reefer_bob)
Take into consideration the exotic fluids that don't attract moisture as well.......
Conventional brake fluild attracts moisture which gets into the lines then evaporates when hot. Hence the need to bleed brakes. But, if you get the new stuff (and wouldn't you know I forgot what the crap is called) you don't have to bleed after the initial install.
Old Jul 18, 2002 | 08:51 AM
ITC Racer's Avatar
Default Re: What break fluid do you guys recommend or use. (Spade)
I run Motul 600 on my IT CRX and love it.
The worst thing for most any brake fluid is to sit in a container that has once been opened. It will suck all water out of the air and become garbage. This also applies but not as much to street cars.
Old Jul 18, 2002 | 10:32 AM
Default Re: What break fluid do you guys recommend or use. (ITC Racer)
Where can I buy Motul?
Old Jul 18, 2002 | 11:15 AM
mrlegoman's Avatar
Super Blue
I'll try to find a link for you.....gimme a minute...
https://www.ogracing.com/ogshell/loadpage.pl?971252+catbrak.html
[Modified by mrlegoman, 12:17 PM 7/18/2002]
Old Jul 18, 2002 | 11:56 AM
Kamin's Avatar
Default Re: What break fluid do you guys recommend or use. (mrlegoman)
Ate superblue
or motul
http://www.collettimotorsports.com
http://www.stoptech.com
Old Jul 18, 2002 | 11:59 AM
TDRacing's Avatar
Default Re: What break fluid do you guys recommend or use. (KAMiN)
What about Ford racing brake fluid? don't laugh, it is very cheap, i think it's DOT 4 and doesn't attract a lot of moisture. Just go to the ford dealership.
Old Jul 18, 2002 | 12:04 PM
JHill's Avatar
Super Blue is what I use.
The higher boiling point non synthetic fluids like the Super Blue are actually more hygroscopic than regular fluids, which is why you need to change it more frequently. When they have water in the fluid, it is considered wet. You should look at dry and wet boiling points. The super blue has a wet boiling point that is higher than the dry of most regular fluids.
[Modified by JHill, 9:06 PM 7/18/2002]
[Modified by JHill, 9:08 PM 7/18/2002]
Old Jul 18, 2002 | 12:41 PM
smokin rubber's Avatar
Sorry but most dot3 fluids are less hydroscopic than other racing dot 4 or 5. I have used the valvoline synthetic for 6 months, and the only time I bleed the brakes is when I go to the track for an HPDE or am working on the brakes, bedding pads, changing calipers.
Old Jul 18, 2002 | 03:54 PM
DC2#428's Avatar
I use Motul RBF600 fully synthetic brake fluid!....awesome!
Old Jul 18, 2002 | 05:53 PM
Power1Pete's Avatar
Motul 600
You can get it at most motorcycle shops. around $15 for half-liter.
Old Jul 19, 2002 | 05:24 AM
Ok everyone now the decision is for either Motul 600 or Superblue.
Old Jul 20, 2002 | 12:26 AM
PyroVTEC's Avatar
New User
I'm not too big on the Valvoline... I've gone through two big bottles already, and they still get a bit spongy after hella hard (read: brakes throwing sparks) runs. I would like to go with a DOT 5 fluid, but I'm not sure if I have to flush the system w/ isopropyl alcohol first or not....
Old Jul 20, 2002 | 11:54 AM
C1V1C's Avatar
works for me too.
I've also heard really good things about superblue, gonna try next time I change the brake fluid.
Old Jul 20, 2002 | 03:30 PM
non-VTEC's Avatar
Castrol GT-LMA DOT 4
works great for me!
Old Jul 20, 2002 | 03:42 PM
Mario's Avatar
Motul 600
Old Jul 20, 2002 | 05:36 PM
Halo's Avatar
Default Re: What break fluid do you guys recommend or use. (non-VTEC)
works great for me!
Haha yes me too
Old Jul 20, 2002 | 05:45 PM
non-VTEC's Avatar
Default Re: What break fluid do you guys recommend or use. (Halo)
Haha yes me too
great minds think alike!
coot_er
14
Feb 7, 2009 01:59 PM
Ghetto Civic HX
63
Oct 6, 2005 01:16 PM
totaled
Feb 12, 2003 11:16 AM
DOHC-Veetec II
Nov 18, 2002 06:15 AM
Lei Siew Long
Jul 6, 2001 04:45 PM
