SH w/ chipped p28 ECU
Old Jun 23, 2008 | 05:16 AM
mrmckie's Avatar
Default SH w/ chipped p28 ECU
ok, i was thinking about running a chipped p28 ecu and boomslang OBII > OBI harness in my 01' SH...other than losing the atts what other negative effects can i expect and do you guys think this is a good move??
Old Jun 23, 2008 | 10:26 AM
mrmckie's Avatar
anyone??
Old Jun 23, 2008 | 10:37 AM
Rob97'SH's Avatar
Default Re: (mrmckie)
nothing other then the lugging around the ATTS. But I wish I went with a p72 for the secondaries.
Old Jun 23, 2008 | 10:40 AM
vinuneuro's Avatar
Default Re: SH w/ chipped p28 ECU (mrmckie)
Unless you need to tune, this is a waste. Don't switch to obd1 for the sake of it.
Old Jun 23, 2008 | 10:51 AM
mrmckie's Avatar
i planned on adding a euro r manifold next to my i/h/e and get the ecu tuned for track/autox use mainly..lateron i was gonna start some head work. hence the need for the ecu
Old Jun 23, 2008 | 10:57 AM
vinuneuro's Avatar
If you track and autox the car, you definitely don't want to lose ATTS. It's worth a ton of time over an open diff. I'd go for Greddy Emanage Ultimate. It lets you directly control timing and fuel (not by messing with the map signal).
OT: I'm in the process of finding a solution to the SH obd1 problem. There's only one circuit that gets in the way.
Old Jun 23, 2008 | 11:19 AM
mrmckie's Avatar
if i autox i would probably use the stock ecu so i could take advantage of the atts still..
Old Jun 23, 2008 | 02:03 PM
A Blue Lude's Avatar
With just bolt-ons you wouldn't *need* to change ECUs.
jayWknight
Apr 20, 2012 06:03 AM
vietelement
Texas -OK -LA (Sales)
May 7, 2010 03:56 PM
dc2_916
Nov 30, 2008 12:49 PM
HondamanXxX
Aug 10, 2007 07:59 AM
Euro98ITR
Feb 7, 2005 01:04 PM
